Author: Subject: Cortina Mk 3. 4 or 5 column surrounds
russbost
posted on 16/10/23 at 09:26 AM Reply With Quote
Bit of a long shot, but I'm sure some of you must have broken Cortina's for bits, I need a lower half column shroud for a Mk3, 4 or 5, not sure they are all the same, obviously a complete set of upper & lower would ensure they match
Anyone got anything they're not looking for a fortune for?
Still need some Bosch distributor cap clips too ...
Cheers Russ
Mr Whippy
posted on 17/10/23 at 06:15 AM Reply With Quote
Have you got a 3D printer?
russbost
posted on 17/10/23 at 08:15 AM Reply With Quote
Nope, & if I did, I would have thought unless someone has already created the files to print it would be quite a difficult job to draw up?
Does anyone know of any 3D files that already exist for Cortina column shrouds? I do have access to several peeps with 3D printers
posted on 18/10/23 at 11:25 AM Reply With Quote
russbost
Any specific reason they need to be Mk 3/4/5 Cortina steering column shrouds?
Is that what steering column you've got / are using?
Could you modify shrouds from a more modern (available) vehicle to suit?
russbost
posted on 18/10/23 at 12:17 PM Reply With Quote
Originally posted by nick205
russbost
Donor was a MK5 Cortina, I've got some other column shrouds here, but nothing that even vaguely matches up, I guess I'll just have to make something up
posted on 18/10/23 at 02:44 PM Reply With Quote
russbost
Makes sense.
I recall using a Sierra column in my MK Indy and being glad I'd kept the 2 piece plastic shroud to refit. Getting something else to line up with the scre fittings would have been hard work. No doubt the stalk apertures wouldn't have aligned either.
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 18/10/23 at 04:58 PM Reply With Quote
Any good Russ
https://www.ebay.co.uk/itm/385662076930?epid=0&hash=item59cb404802:g:ricAAOSwJeJkfjn0&amdata=enc%3AAQAIAAAAwMXua2nEXFoM0LS995UjMe%2BWWaaje7lBc 8UqwbC%2FtHsh7tPhpedurtUJjA7c1k5vaA70yPa%2B5BUEW2f%2FqUPb69LdnLUocd8x6%2FNCeOrwRxmfpRgURe3TZTl7%2BBXwGemk4I95kAtoJEbqVM14XuvdhpiHISfAg9bIDWYMrFA7ASSJH QhJLe0Xm1ilgxYfX8luOiNN3UxiG9B4ocdesWW5OZ%2FUnjvDNCoL2t2ypSyxzp41sTla%2BmKvrTbeSEP3d4owfg%3D%3D%7Ctkp%3ABk9SR4aewbvoYg
