richijenkin
posted on 2/5/05 at 01:43 PM |
Latest pic
Dudes....
Just thought I'd upload my latest pic!!
![](/galpreviews/Day 10b.JPG) ![April 2005](/gallery/Day 10b.JPG) April 2005
jack trolley
posted on 2/5/05 at 06:30 PM |
Those cheap Screwfix workbenches have a max. load of 100Kg.
here ![](/images//smilies/sad.gif)
indykid
posted on 2/5/05 at 07:09 PM |
in theory, yes, but that would be a safety margin deducted.
in practice, they'll take me and my dad stood on one (plasterboarding ceiling, what can you say? ) which must be about 160kg, 170 odd including
the board.
i'd be more worried about a B&D workmate as there is no vertical tubes down to the floor in a straight run, just the latch to hold it.
anyway, nice car, looking good
tom
OX
posted on 2/5/05 at 07:47 PM |
lmao ,what you cant see on the work bench is the big whole made by the arc welder.
richi ask shed if you can borrow the stands he used
DarrenW
posted on 3/5/05 at 08:05 AM |
tom
Dont worry about the workmates. I used to be the production supervisor and Senior Manufacturing Engineer on the Workmate production line at Black
& Decker. They were load tested to around 500Kg (not all of them, just a test sample every shift). We also tested them to destruction to test the
rivets, latches and welds.
Of course they are not warranted to this load but it shows that manufactureres do at times add large safety factors. (Iam referring to the proper
workmates here (536, 750's etc etc not the daft little scissor cheapo one that is made under license elsewhere).
(This thread in no way implies that you should overload any support device beyond the manufacturers stated max safe working loads. No workmates are
stated to be OK to stand on. Also strength is compromised if you accidently saw through the jaws!!!!).
posted on 3/5/05 at 09:06 AM |
What idiot would do that? Does drilling through them count as well?
richijenkin
posted on 3/5/05 at 12:14 PM |
lol..., my mate wanted to test his tig welding skills on the legs of my bench and put a big hole in it. Maybe he might want to test his saw out
someday???
tractorboy
posted on 3/5/05 at 05:09 PM |
its not just the work mate you need to worry about .. but you may need a few "workmates" to help you lift it off the tressels! especially
when you have to put a set of wheels on it too . just a thought.
scott
richijenkin
posted on 3/5/05 at 05:30 PM |
I'd like to keep it on them till its fully built. 3 people should do the trick
OX
posted on 3/5/05 at 06:17 PM |
lol rig,make sure that if mum helps you she completly moves the bench out of the way before she says its clear to put it down,i nearly put my back out
when peter and me started to lower to find she hadnt pulled it out far anough
richijenkin
posted on 3/5/05 at 09:42 PM |
I was thinking if me and mum lift the car then gran can pull the stool out
Bananaman
posted on 4/5/05 at 08:13 AM |
if you're straining that much when you lift the car that Gran will need to pull the stools out then you have a problem. Buy some incontinence
pants!!
Big cheers
Michael
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
posted on 4/5/05 at 09:14 AM |
Quick quick !
The turtle's getting curious. Go before you start lifting as the resulting straining may cause the stool to be a touch premature.
