jos
posted on 7/11/05 at 03:51 PM |
SVA Booked 17/11/05 - NOW WITH PICS
Well Ive only gone and done it, booked the SVA
I will be at Shrewsbury SVA centre at 0800 in the morning of 17/11/05 quivering with fear.
[Edited on 14/11/05 by jos]
pajsh
posted on 7/11/05 at 04:11 PM |
Best of luck mate.
There pretty sound blokes really so no worries.
I was really uptight due to my wifes sister having died two days earlier from cancer at 44 so it was a grim day.
Looking back if I'd been in a better frame of mind I would have enjoyed it more.
And if I'd started from scratch and know about LB earlier on it would have saved me alot of fails.
Live & learn.
I used to be apathetic but now I just don't care.
mac1ZR
posted on 7/11/05 at 04:52 PM |
Good luck Jos
jos
posted on 12/11/05 at 08:15 PM |
I would very much appreciate everybodies opinions on improvements to get through SVA.
DarrenW
posted on 14/11/05 at 09:51 AM |
Looking good Jos. Cant see anything obvious.
What did you use on the shocker height adjuster nut?
Headlight glass securing screw - how did you get the nut cover to stay on?
A couple of things that i know Gosforth are hot on,
1. battery lead security and no exposed conductors. Your -ve lead looked a bit loose.
2. Bonnet trim security - i have to glue mine on (crazy i know but easy to do).
3. Exhaust clamp bolt - have you cut yours down? (shortened it?).
Someone failed recently using those rear reflectors iirc. I guess you have another pair ready just in case.
Ive been putting my stickers on - car is starting to look well smart.
Q not SVA related - throttle pedal. How did you get yours to stay in the rest position? Previously i could only get mine to rest in one position by
tightening the banjo fitting to the pedal. This will lead to early breakage as these fittings have to be left loose. I have just had to weld a strap
across the top of the pedal brackets with a bolt thro' which now operates as an adjustable postion stop. It works great but took some sussing
out. What have you done?
Also how did you secure the other end of throttle cable to the carb sphere jobby thing. Does it have a metal clip? Mine doesnt so ive been messing
with cable ties but they are very professional.
posted on 14/11/05 at 11:19 AM |
How high is the bottom of your rear fog lamp from the floor? Also is your numberplate light shining upwards? It may fill up with water if it gets
rained on and could be commented on.
[Edited on 14/11/05 by Peteff]
jos
posted on 14/11/05 at 11:54 AM |
On the adjustable platform Ive used a length of hose with a zip tie through the middle, I'm going to redo them as I want some larger diameter
hose. Thanks for reminding me.
You can very carefully cut a t section out of an M12 nut cover so that it grips to the hollow behind the headlight bolt head using cable
cutters/pliers.
I'll look into battery leads, thanks.
Ive rotated the exhaust clamp so that it is below the theoretical floor line - therefore un-testable.
I will buy some other reflectors although Mark is primed to argue the toss if they say anthing as there is nothing in the manual regarding reflector
size.
All Ive done on my throttle pedal is tightened the pivot bar so that its just tight enough, thats all.
On the other end of the throttle cable Ive got a tear drop shaped bit and looped the throttle cable over it securing it using 2 mini cable clamps
similar to those used on the handbrake, and made it tight enough to not fall off, and as its spring loaded it wont fall off during driving, at least
it didnt fall off when I was mucking around driving this weekend attempting donuts.
Yes, i know I shouldnt be doing them as the engines only got 2 miles on it since rebuild but I kept below 4k revs and only managed a half donut.
andytmc
posted on 14/11/05 at 12:50 PM |
Hi Jos
Good luck with the SVA, it looked pretty good to me - hope it doesn't rain on the day!
I'll be round for a ride when you've passed
jos
posted on 14/11/05 at 02:09 PM |
Just checked the fog light and its 300mm off the ground
posted on 14/11/05 at 02:25 PM |
That's o.k. then.
Hornet
posted on 14/11/05 at 04:16 PM |
very nice looking car!!!
What height front indicators of floor?
O and your bonnet clamps are upside down (wont fail SVA for that though)
cheers John
jos
posted on 14/11/05 at 04:24 PM |
Ah ha, are they.
Quote "You laugh at me because I'm different, I laugh at you because youre all the same".
If one of the latches does let go whos latches are more likely to remain connected, mine or yours. Wont yours just fall open, aided by gravity??
jos
What height should they be and I'll check this evening
Hornet
posted on 15/11/05 at 08:10 AM |
Hi dude
Indicators need to be a min 350mm from the floor to the bottom of the lens.
And the manufacturers of the clamps must have it wrong for all these years.
It seems you are right..... NOT
Cheers John
jos
posted on 15/11/05 at 08:23 AM |
Yup just wound my struts up and inch to raise them and will pump up tyre pressures as an added bonus as they were at 325ish
I didnt see any right or wrong way on the instructions for the bonnet clamps. Could you show me them please.
Hornet
posted on 16/11/05 at 08:20 AM |
hi m8.. Remember adjusting ur shocks up that much will transfer a lot of weight onto the front wheels. You may find that your rear wheels will lock up
too easy under braking.
Best you set ur corner weights and move the indicators if they are still a problem.
Cheers J
jos
posted on 17/11/05 at 03:15 PM |
Well the time came to strtup and travel to SVA and an hour later hafl anf hour after the test was due to start I was still trying to get her started
with no luck.
Got to pay the £150 again and can claim back £100 for rescheduling.
Just got to get the thing running, ticking over & emissions sorted.
MAC#1 here i come
posted on 17/11/05 at 03:34 PM |
What a PITA!
That happened to me on my first SVA attempt - except I managed to get within a mile of the test centre... on the 2nd attempt I hired a trailer, just
in case.
Better luck next time.
rgds,
jos
posted on 17/11/05 at 03:47 PM |
I think I might look into that also but I want to make sure the emissions will pass before rescheduling.
One good note is that if it DOES drag on I could register it in 2006 rather than 2005, getting a year younger car...........
DarrenW
posted on 17/11/05 at 04:10 PM |
So what do you think has happened Jos? If it was running ok yesterday to get MOT and you were able to do donuts on Sat there cant be much wrong.
Is it turning over but not firing???? or something else?
Iam absolutely gutted for you. You need to be quich now and re-schedule or ill be beating you to the test!!!!! Got the stupid daft waste of time
questionairre yesterday. At least i know they have my form, but what the hell was the second form all about??????
andytmc
posted on 17/11/05 at 04:47 PM |
Bad luck Jos.
Did you do a Basil Fawlty and threaten to give it a damn good thrashing??
Give me a shout if I can help - don't know much about Pinto's but have a good selection of hammers....
bigrich
posted on 17/11/05 at 09:48 PM |
bad luck jos sounds like the pinto got a touch of stage fright keep on smileing your almost there![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
jos
posted on 18/11/05 at 09:16 AM |
Yup, shall do. She was turning and we came extreemly close to starting as she nearly caught a number of times but not the whole schebang.
Stagefright - Yup definately.
When she has been running shes been running very rich as theres a bad smell and a black tinge to the exhaust emissions. Also the sniffer that was
used was registering off the scale instead of the les than 4.5% I was aiming for.
So now I'm going to trailer her to Sheffield so that the lads can get their grubby hands on her and give her a good seeing to.
greggors84
posted on 18/11/05 at 01:50 PM |
I had a similar experiece except I managed to get it to the SVA! It started fine in the morning, i filled up with fuel about a mile from the station
and it started fine. I pulled up when i was there, went into the office and he asked me to pull it up to the line. Got in and it would hardly turn
over and everytime i tried it just got worse. He jumped it for me but said there was no point doing the test as he would have to start it about 20
times again. I then drove home praying not to stall it.
Im hoping its the battery as I charged it the week before and it seemed fine on the way there and was ok running on the way back. If it was the
alternator i would have thought it wouldnt run very well with no charge in the battery and no current coming from the alternator.
The battery will be easy to change but it will be a pain trying to find another suitable alternator. Even though its brand new so i cant see why it
wouldnt work.
I still need to check both as i went back to uni the same day so havent had chance to look at it since.
The only good thing about it was he never charged me for the test, i think he felt really sorry for me, he gave me a number to quote the next time i
phone up for the test.
Chris
The Magnificent 7!
