Author: Subject: Indicator problem
Smartripper
posted on 3/1/06 at 07:56 PM Reply With Quote
Indicator problem
Hello,
I got a little problem, the indicators on the right are working, but on the left they don't, checked al the wiring and that is oke....
What could it be ??
Daniel
fesycresy
posted on 3/1/06 at 08:10 PM Reply With Quote
Bulbs ?
emsfactory
posted on 3/1/06 at 08:22 PM Reply With Quote
relay, bad connections, shorting, broken wire.
could just be sulking.
Smartripper
posted on 3/1/06 at 08:31 PM Reply With Quote
The bulbs are oke,
There is no broken wire i could check for short circuit.
k33ts
posted on 3/1/06 at 08:45 PM Reply With Quote
start at the stalk to see if youve got power coming out
it must be goin in as the otherside works
Smartripper
posted on 3/1/06 at 09:08 PM Reply With Quote
Hello,
The stalk is oke.
But when i short the wires in front of the stalk then the indicators did'nt work either.
Deckman001
posted on 3/1/06 at 09:10 PM Reply With Quote
relay ??
Jason
k33ts
posted on 3/1/06 at 09:20 PM Reply With Quote
is the left not flashing or not coming on atall
Smartripper
posted on 4/1/06 at 07:04 AM Reply With Quote
the left is not coming on at all.
Genesis
posted on 4/1/06 at 09:40 AM Reply With Quote
Thinking about this logically;
1. Power from Battery to Hazard Switch
2. Power through Hazard switch to switching relay (ON/OFF)
3. From switching relay to stalk. (1 wire)
4. Through stalk to either side (now two wires) through warning bulb (must be wired in parallel)
5. Bulbs flash
Logically it is 4 given that the right hand side works.
Do you have bulbs in left side otherwise all you will get is buzzing from flasher relay.
Failing that check wiring again as it is wrong from stalk. Check LHS output on stalk when live using voltmeter.
Actually - those warning lights (dash lights) look like they are wired in series therefore if a bulb goes down one side will not work could be that!!!!
[Edited on 4/1/06 by Genesis]
Going fishin'
Smartripper
posted on 5/1/06 at 03:38 PM Reply With Quote
Hello,
There was a lamp busted in the display, and this was in serie so no contact.
New bulb......ready,
Thanks for the advice..
Smartripper
