Mave
posted on 2/2/06 at 07:32 PM |
Question for the Zetec experts: HELP!
I'm trying to solve the bad idle behaviour of my Zetec, and was pointed in the direction of a Fault Code Reader. This should be plugged onto a
three-pin connector, and could tell me what's wrong.
I'm using the standard Ford ECU, and a relatively standard Zetec loom (don't know exactly which car it's from). It turns out my loom
doesn't have the three-pin diagnostic connector. Actually; the ECU connector is missing a pin (no: 48) which should go to that connector!
So.......how will I be able to read the Fault Code!
I have another Zetec loom (a half one that is), which does have the three-pin connector. Would it be possibly to just plug my ECU to this loom, and
read the code? It's probably not that simple, as the ECU needs juice to produce the codes. And how could I easily feed that, with blowing the
ECU?!?!
Marcel
posted on 2/2/06 at 08:02 PM |
Some Mondeo Zetecs circa 1995/96 used the 16 pin EOBD diagnostic connector before it was officially fitted. --- they aren't truly OBD2 or
EOBD compliant this sometimes called OBD 1.5
The 16 pin connector was fitted adjacent to the steering wheel shroud
posted on 2/2/06 at 08:11 PM |
I forgot to add try this site
http://www.btinternet.com/~madmole/Reference/Idle.html
Mave
posted on 2/2/06 at 08:28 PM |
Hmm, thanks, I must be the lucky one (ahum) having the rare 16 pin version currently in my car. 15 of the wires connected to this connector go nowhere
in my car, and 1 is going to pin 17; where one of the three diagnostic pins should come from too.
Would it be possible to just add a pin to the ECU connector? Than I could just build the three-pin connector in myself. That would save a lot of
hassle!
I discovered the madmole site yesterday evening! Very usefull, and it gives all the fault codes.
Marcel
stevec
posted on 2/2/06 at 08:39 PM |
Before going to far, Have you cleaned all the black crap from the throttle butterly, Remove the air intake pipe and have a look, your problem may not
be electrical.
Steve.
Mave
posted on 2/2/06 at 08:41 PM |
What's the best way to clean it? I removed quite a lot of it, but there's still a lot left. But that doesn't brush off easily.
Marcel
posted on 2/2/06 at 08:46 PM |
Carb cleaner or thinners
stevec
posted on 2/2/06 at 08:54 PM |
Jam the trotter wide open, and wrap a clean rag with some solvent on around a smallish scewdriver and you can get into the arkward corners, dont
forget the edges of the butterfly itself.
Steve.
tks
posted on 2/2/06 at 08:56 PM |
mhhh
i dunno nothing about you situ but i think you need to search for an hayness manual.
some MCU have just 1 pin to do the task.
It could only be an light pin wich will tell with blinks what the problem is.
Cant you just hook up the dashboard of that kind a car and look at the Engine control light?
if there is a problem that one would light to.
Tks
CairB
posted on 3/2/06 at 01:01 PM |
Don't know if it's relevant but I seem to remember that the EECIV ECU that i had on a pinto needed to go through a self calibration
process after the power had been removed. I think it was to do with determining the idle valve characteristics.
Colin
andytmc
posted on 4/2/06 at 08:19 PM |
Just to follow up on what Colin said, my Haynes EFI Diagnostic manual says that after the ECU is reset, it is likely to have a rough idle. It
recommends getting the engine up to temperature, then running at 1200RPM for 2 minutes, followed by a few miles driving.
When the ECU is reset on mine, the idle ceratainly hunts for a while before settling down.
Marcel - is it a general poor idle you have or is it cutting out some times? If the its the latter then its may be worth checking the idle speed
control valve as they can get a bit sticky. Fairly easy to clean with carburrettor cleaner though.
Hope this helps
Mave
posted on 5/2/06 at 08:23 AM |
The idle is not just bad; she simply dies instantly when the throttle is closed. The idle control valve is open at that point, so I've got the
feeling that this isn't the problem.....
I have been able to insert a pin in the ECU connector, and now have a functional diagnostic connector. So now all I have to do is find a fault
reader.....
Meanwhile, I also discovered that I had some vacuum leaks in the manifold. I'm hoping to have sorted that out.
I'll report when the problem has been solved.
Marcel
Triggsy
posted on 5/2/06 at 09:57 PM |
I had this exact same problem on my Zetec powered westfield. When i fitted the standard injection system i didn't connect the crankcase breather
pipe to the inlet manifold so it stalled every time i let off the throttle at junctions.
When i did finally fit it the car idled fine at close throttle.
Simple fix really.
Simon
Mave
posted on 6/2/06 at 07:19 PM |
Nope, I did check the crankcase ventilation, and it's connected to the manifold. Right now the manifold is off, and newly sealed on the inside.
I hope to check it later this week to see if it helps......
Thanks anyway.
Mave
posted on 8/2/06 at 05:27 PM |
Well, she idles nicely now. I sealed up the (custom) intake manifold, and cleaned the throttlebody.
But now she dies when I start revving!!
I started her up, with the throttle open a bit (holding RPM steady, sometimes revving a bit). This went very well, so I slowly closed the throttle,
untill it was completely closed. And she kept on running fine. So I let her run for a minute or so, and then I touched the throttle again. This time
there was no increase in RPM at all, and only a rough reaction from the engine (bit shakey).
So........now what?!?!?!
I wanted to do a little dance when she finally idled, but now I don't know whether I'm going forward, or actually going back!!
![](/images//smilies/sad.gif)
Mave
posted on 12/2/06 at 02:52 PM |
SOLVED!!!!!
Today I found out that somehow there was a bit of a problem with the fuel supply. The pump was sucking alright, but it couldn't get enough from
the tank. Maybe there just wasn't enough fuel in it......
Anyway, I filled her up, fired her up, and she settled into a nice idle. And was very willing to rev too. So I guess the problem (whatever it was) has
been solved!!!
Time for a dance of joy!
![](/images//smilies/bigsmile.gif)
