Spadeadam
posted on 23/2/06 at 08:14 PM |
4a-ge phase 3 - from which donor?
Hello there - I've read and searched a few old threads in SEARCH mode, but can't find any listing of which engine comes from which car
The phase 3 (140bhp?) IIRC seems to be the one to have (from this marque) but I can't seem to find from which models and years they were
available?
Any pointers on this please - getting eyes like saucers with trying to check this on gooooooogle
Have to go out now, but will check back later tonight or tomorrow morning.
Thanks & TTFN
Rob Lane
posted on 23/2/06 at 09:05 PM |
Corolla Gti from 89-91.
Getting scarce now and desired by the Bradford mob.
UncleFista
posted on 23/2/06 at 09:07 PM |
Very true, they're like road fleas here in sunny Bradford
Tony Bond / UncleFista
Spadeadam
posted on 24/2/06 at 10:19 AM |
Thanks Rob & Tony for those replies.
So, of all the toyota 1.616v - that is the engine to get.
Am I correct in thinking this?
With say Omex ECU, bike throttle bodies, stainless 421 exhaust - what kind of power would that produce?
Which are the preferred bike TB's - I seem to recall GSX 600 or 750 cropped up a few times in threads. Has anyone bought any of these recently -
just wondered what the going rate was?
Comments re above most appreciated.
rusty
posted on 24/2/06 at 10:57 AM |
The 4age rev3 is 129bhp in the corolla and has the following good point.
It has the stronger 7 rib block, larger rod pins and piston spray bars.
It also has no TVIS, small port head and different cams.
With a cam upgrade on standard ECU you would get 150-160 but this is about it enless you want to go forced induction.
As regards your comment about 140BHP I think that was the stock power from the REV 1 4AGZE supercharger witht he REV 2 being 160.
Prez
posted on 24/2/06 at 12:52 PM |
If you upgrade the cams past about 260 degrees duration you will need to have an uprated ecu. It is possible to wring upwards of 200 bhp out of a 4age
if your pockets are deep enough!! check out this link for loads of 4age tuning info:- http://www.billzilla.org/4agmods.htm
Good luck
Prez
posted on 24/2/06 at 12:54 PM |
Oh and the small port phase three is definately the best base to start with, If you are looking at making silly power, 200bhp+ you will need the big
port head to allow the engine to breathe properly.
Spadeadam
posted on 24/2/06 at 09:36 PM |
Thanks for the above advise will look into this.
Thanks also for the U2U - I have replied.
Will have to keep my eyes peeled for one of these.
Have contacted a local factor to see how much it would cost for the parts to rebuild, shells rings etc. I recon at the age they would be 1989/91, that
they could do with an overhall.
