Monkeybasher
posted on 25/2/06 at 03:24 PM |
Msq for 2.0l zetec, gsxr bodies, st170 injectors
Does anybody have an good fuel and ignition map for megasquirt V3. I have a 2.0l zetec with GSXR throttle bodies running ST170 injectors. I have one
for a standard zetec but was wondering if anybody has a more exact one.
Monkeybasher
posted on 25/2/06 at 04:47 PM |
quote: Originally posted by CaLviNx
Hi
If you read the tuning section on the megasquirt website it explains in detail how you "tune" the base map to suit your exact engine, and
a run on a dyno will help you (optional), or as in the "spirit" of megasquirt get a mate to run a laptop connected to your megasquirt,
while you drive and set up the table at the set locations for fuel and ignition, and if you do a bit of a search via google you will manage to throw
up dozens of maps, if your too lazy/inept to map it yourself.
I plan on using Megatunes own autotune facility along with my LC1 to tune so hopefully need for a mate. This should get things close and when I have
more time I will learn how tweak myself, although I have read that section. I have spent that long reading, building and understanding my megasquirt
my enthusiasim is having a low at the last hurdle so wanted to cut a corner wth a good map to get things going quite well. However I suppose just a
little bit more work and I will hopefully be close. Although my new starter is dying with all the cranking.
