liam.mccaffrey
posted on 9/3/06 at 11:23 AM |
Megasquirt and Bill S
i think im going to order Megasquirt from Bill, could people comment on what i need
MS 2 with v 3 board
LC-1 wideband sensor
will the above provide fuel and sparks without edis and how much would i expext to pay, i wanted to sound you guys out before i hassled bill
Build Blog
Build Photo Album
BKLOCO
posted on 9/3/06 at 11:39 AM |
NO!
For sparks without EDIS you need MSI NOT MSII. any version of the mainboard will do but I would opt for V3 as it's more complete ie. flyback
built in etc.
There is no code written yet for MSII to run a second coil driver yet (Unless you fancy having a go!)
Talk to Bill he will advise you exactly what you need.
He is not a commercial organisation so will not sell you things you don't need just to make a profit.
He actually prefers to discuss your requirement so you get it right first time.
[Edited on 9-3-06 by BKLOCO]
liam.mccaffrey
posted on 9/3/06 at 12:03 PM |
so the above with an edis module will give fuel and sparks
(email to bill sent)
Build Blog
Build Photo Album
BKLOCO
posted on 9/3/06 at 12:51 PM |
OK this is how I understand it.
(running for cover already)
MS I
Will give you fuel and spark with the standard code using an EDIS module if you don't have a dizzy. With a dizzy you dont need the EDIS. With
extra code you can run a second coil driver allowing you to run without either a dizzy or EDIS. Without a dizzy you do need a trigger wheel on the
crankshaft.
It has 8 X 8 tables for both fuel and spark.
MS II
Will give you all of the above except that there is no code written to run a second coil driver yet. Therefore you need either a dizzy or an edis and
trigger wheel.
It is a 24 MHz 16 bit processor rather than 8 MHz and it also has a much larger user ram. The look up tables are 12 X 12 giving better resolution.
All the various versions of the mainbord will run either processor. However V3 is much more complete with less periferal circuitry required.
Either MS I or MS II will run a narrow band O2 sensor (lambda). Both will need an extra decoder to run wideband O2.
Hope this helps.
As I said before Bill knows as much or more than anyone regarding MS and if your not sure what is best for you then go with his advice.
EDIT
I couldn't agree more with Mark above by the way.
You need to:
read read read.
ask a few questions.
then.
read read read.
and keep on reading till your brain hurts.
You need to understand,
and more importantly WANT to understand.
BKLOCO
posted on 9/3/06 at 04:16 PM |
Either I haven't worded it properly (most likely) or you've misread it.
What I was trying to say was:
There is code available to run second coil driver with MS 1 but not yet with MS 2 (as far as I know)
Chris_G
posted on 9/3/06 at 05:13 PM |
MS I
My understanding is that MSI with the extra code also handles 12x12 tables
Chris
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
posted on 9/3/06 at 06:22 PM |
Strangely I was looking at exactly this earlier today as I really don't fancy edis, twin coil wasted spark seems logical.
http://www.extraefi.co.uk/products.htm
