Author: Subject: Help needed 20l zetec on megasquirt.
mr zefect
posted on 12/3/06 at 11:03 AM Reply With Quote
Has anyone got a map that would be a good starting point for me im using gsxr750 throttle bodys megasquirt 2-2 with 2.25bs14 beta with sqirt+spark with edis 4 also im using light green injectors out of a 1800 does any one no the cc min they are it is running but runs very rich on idle i have set the fuel constants i have no o2 sensor on it yet would this have anything to do with it running rich any info would be very helpfull.
the_fbi
posted on 12/3/06 at 01:00 PM Reply With Quote
You got the bosch part number of the light greens?
posted on 12/3/06 at 02:37 PM Reply With Quote
http://www.telusplanet.net/~chichm/tech/injectors.pdf
Might be an idea to check your coolant temp sensor characteristic is properly set up.
Saw some zetec maps for download somewhere recently -- i will have a look around my browser history.
Rob Lane
posted on 12/3/06 at 05:50 PM Reply With Quote
Without an EGO on it you should set the Ego step % to 0. This is in fuel menu under EGO.
Which version of code are you using 13c or later ?
mr zefect
posted on 12/3/06 at 08:06 PM Reply With Quote
Im using megatune 2.25 beta with squirtnspark extra 024s11.
mr zefect
posted on 12/3/06 at 08:12 PM Reply With Quote
code for injectors are 928f b1c
the_fbi
posted on 12/3/06 at 08:15 PM Reply With Quote
I presumed they'd be Bosch's. Either they aren't or thats not the right number
Bosch should start 0 280
mr zefect
posted on 12/3/06 at 08:35 PM Reply With Quote
are the numbers on the top coloured part if so that is the number.
