Author: Subject: fitting different injectors to gsxr tb
oioi
posted on 15/3/06 at 08:16 AM Reply With Quote
ive just bough myself some gsxr1000 throttle bodies but the standard injectors wont flow enough for what I need.
Is there anything thats a straight swap? Needs to flow around 320cc/min.
If not what have people used? The little PICO ones or something different? Anything I can rob from a scrappy that will do the job?
OiOi
That is the Curse of Speed which has plagued me all my life I am a slave to it. On my tombstone they will carve,
"IT NEVER GOT FAST ENOUGH FOR ME." - Hunter S Thompson
muzchap
posted on 15/3/06 at 09:17 AM Reply With Quote
I'm using some Supra (non turbo ) injectors. Green top.
I paid about $50 for them from the states - quite rare over here?
They flow about 350cc/min
I got Gixer 750 throttle bodies ;-)
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
stevebubs
posted on 15/3/06 at 09:31 AM Reply With Quote
Got some normal car injectors. You should be able to get a good seal between the injectors, bodies and rail. However, IIRC the rail will need spacing away with spacers
Stephen
GeoffT
posted on 15/3/06 at 10:06 AM Reply With Quote
Are you sure the GSXR 1000 injectors won't flow enough? I'm using GSXR600 injectors (on a Xflow) and was surprised to find that a bench test of these revealed a flow rate in excess of 300 cc/min. This is further bourne out by the fact that the duty cycle of these injectors at WOT rarely exceeds 50%, indicating they're well within their capability.
I don't know what the flow rate of the 1000 injectors is, but wouldn't have thought it less than the 600's - these are good for up to 200 bhp by some accounts. Maybe your hp will be greater than this, but if not I'd be inclined to give them a try before you spend any more of your hard earned cash....
ATB, Geoff.
oioi
posted on 15/3/06 at 05:41 PM Reply With Quote
the quoted figures ive seen are 230cc/min, not sure thats right though. seehere.
Im running about 225bhp so even at 300cc/min I would be struggling.
what was the power spec of gsxr1000? about 160bhp ish?
stevebubs
posted on 15/3/06 at 05:59 PM Reply With Quote
Think I've got some 380cc/min car injectors around here somewhere.
Unchecked - bought them off fleabay about 18months ago.
can have a hunt around and see if I can find them - if you want them, make me an offer.
S
