zzr1100rick
posted on 31/3/06 at 05:26 PM |
fuel pump suck
Hi can anyone tell me if a silver bosch fuel pump from a injected sierra will suck fuel . As pump is looking like it will be mounted half way up
the tank side externaly
posted on 31/3/06 at 05:42 PM |
Sucking fuel is a bad idea in warm weather you could get vapour locks and also could shorten the life of the pump.
However a couple of inches above the bottom of the tank is ok.
mark chandler
posted on 31/3/06 at 06:06 PM |
Sierra's have the pump below the tank for a reason.
Once fuel is flowing its not an issue, however the pump cannot prime itself by drawing fuel so unless you start with more than 1/2 tank full you may
have problems. An EFI pump drawing air will ruin itself in a short time.
There is a way out, use a low pressure diapham pump (which can draw air) to circulate fuel to a swirl pot up front, then mount this above your EFI
pump and have a superior setup.
Regards Mark
zzr1100rick
posted on 31/3/06 at 09:33 PM |
Cheers Mark
I was hopeing to get away from having to have 2 pumps
the feed pipe is 15 mm so there is a fair amount of fuel head i will just have to get the pump as low as i can
