Author: Subject: Accelerator Sensor
tks
posted on 20/4/06 at 08:32 AM Reply With Quote
Accelerator Sensor
I´m in hard need of a brand accelerator sensor.
i have seen until now 1 setup thats like a electric motor with a ring on it, the spring on the axle makes it automaticly return.
the cable of the pedal is attached to the ring. See sketch for the idea..
Question:
- What are now days the sensors like.
- Anyone has seen this kind of thing and on wich car was it...
striker4age
posted on 20/4/06 at 11:41 AM Reply With Quote
Is that a throttle position sensor/switch, frequently called TPS?
Not too sure about brands, I got my first one with my Emerald and the second one with the bike TBs.
tks
posted on 20/4/06 at 12:10 PM Reply With Quote
well in fact i just changed plansss
Well i will need 2 Tps sensors..
sow if anyone is upto the job??
Tks..
prefered to be identical..
stevebubs
posted on 20/4/06 at 12:26 PM Reply With Quote
Look on www.rswww.com for a potentiometer that should do the trick
