graememk
posted on 23/4/06 at 06:46 PM |
mega wotsits working 1st time
so ok i'm nearly at the engine starting time, whats the chance of my mega squirt working 1st time around.
if not, what next after checking for spark and injectors squirting?
Danozeman
posted on 23/4/06 at 06:51 PM |
My megajolt worked first time but the car wont start..
My aim for getting it started this weekend has gone out the window.
Dan
graememk
posted on 23/4/06 at 06:53 PM |
so if it dosnt start what next ?
big_wasa
posted on 23/4/06 at 07:08 PM |
So What did you end up with then Graeme Msns or Ms+ edis. ect ect.
How did you work the Vr sensor. Hall efect in the dizzy or a crank mounted toothed wheell.
Oh and can I come and watch
graememk
posted on 23/4/06 at 07:22 PM |
ms, edis, tooth crank wheel.
just finishing off the build now, rear lights went on today, i cant download my pics from the phone as i've lost my blue tooth thingy.
Danozeman
posted on 23/4/06 at 07:33 PM |
Work at it until it does
My problem is the fuel i think.
Dan
chriscook
posted on 23/4/06 at 10:15 PM |
Megajolt worked 1st time -sort of. I tried without the MJ plugged in and just the EDIS module and it didn't start - turned out I have the wires
to the different halves on the coil pack the wrong way round. I think quite a few people have had the same problem - swapping the plug leads over
fixed it until i sorted the wiring properly.
Chaz
posted on 24/4/06 at 03:39 PM |
Megajolt worked first time along with my first engine starting last night. Just turned the key and it all went!
graememk
posted on 25/4/06 at 06:21 PM |
just getting a but twichy with things i dont fully understand
paulf
posted on 25/4/06 at 09:50 PM |
Mine started after a few attempts and ticked over ok after a few adjustments, I then realised I had misconnected the injector wires and was only
running on 2 injectors. Corrected the wiring and got it running fairly well after about 30 miles of datalogging and adjustments.
Paul.
Danozeman
posted on 28/4/06 at 06:50 AM |
turned out I have the wires to the different halves on the coil pack the wrong way round. I think quite a few people have had the same problem
I had that problem.
Dan
