Author: Subject: GSXR throttle bodies what this? 2
piddy
posted on 9/5/06 at 05:08 PM Reply With Quote
There is a four way junction box/valve. It has one pipe that conects to the throttle bodies via a vacuum pipe the other threee outlet are 12mm. what is it? Rescued attachment v.GSXR.jpg
ruudbeckers
posted on 9/5/06 at 05:21 PM Reply With Quote
I guess it's the fuel pressure regulator, but I'm not sure, mine didn't have it.
Major Stare
posted on 9/5/06 at 05:42 PM Reply With Quote
I agree.
I wouldnt bother with the pipe that links the carbs to the Fuel Pressure Regulator.
Instead, link it to your ECU/MegaSquirt/Emerald or what ever you are using.
Jon "FISH"
yorkshire-engines
posted on 9/5/06 at 05:44 PM Reply With Quote
Hi its not the fuel press regulator it a vcv valve dissconnect it and blank off the pipe
also if you dont want map sensor ill have it
cheers malc
piddy
posted on 9/5/06 at 05:55 PM Reply With Quote
What should I do for a fuel pressure regulator?
What have other done?
Best place to buy etc.
16vmini
posted on 9/5/06 at 06:26 PM Reply With Quote
when i ran my 2litre 16v vauxhall lump on suzi TB's , i used the std suzy injectors and pump , and did not use a pressure regulator ... i just mapped it to cope.
Matt
stevebubs
posted on 9/5/06 at 06:27 PM Reply With Quote
Is there not one bolted to the fuel rail?
If not, either go and buy a one from an appropriate car or buy an aftermarket one.
Q: Does the fuel rail have a return?
piddy
posted on 9/5/06 at 06:48 PM Reply With Quote
No, no regulator on the fuel rail and no return on the fuel rail.
posted on 9/5/06 at 07:05 PM Reply With Quote
Matt
Not a good idea unless the suzuki pump was designed to be used like this.
If you are relying on the safety pressure relief valve built into the pump itself. This will not necessarily give you a stable fuel pressure at all injector durations, and as you have no return fuel line you risk vapour locks in the fuel rail.
16vmini
posted on 9/5/06 at 09:56 PM Reply With Quote
its exactly how the suzuki was done , the fuel rail did not have a return , the pump was designed for it.
i ran a small swirl pot up front with the suzi pump mounted in it , this tank was then fed by the old weber pump at the back.
Matt
Matt
stevebubs
posted on 11/5/06 at 09:06 PM Reply With Quote
Yep - sounds like quite a neat solution, Matt.
alternative would be to tap the end of the rail and fit a return. You can then use a standard car pump / regulator.
Stephen
posted on 11/5/06 at 11:12 PM Reply With Quote
Dave Walker of Emerald is not too keen on it! On top of the other disadvantages I stated above, it may also be difficult to bleed any air out of the fuel rail, which is done automaticly when you have a return.
