Author: Subject: Fitting trigger/toothed wheel
Major Stare
posted on 15/5/06 at 01:42 PM Reply With Quote
Trying to fit toothed wheel but im struggling to remove the bottom pulley (X-Flow).
Have removed the starter and tried to wedge the fly wheel but no joy.
Best way to do this ???
Jon "FISH"
posted on 15/5/06 at 01:48 PM Reply With Quote
wedged flywheel???? ok, guess you have not got past the removal of the bolt yet?
I take it you are using a big breaker bar but the bolt is not shifting? use a bigger bar or press hard on the bar and whack it will a rubber mallet to shock it - impact gun has the same effect.
On Land Rovers, & this shold work for other cars, put a breaker bar and wedge it against the chassis, usng straps, then turn the engine on the starter.
I'm sure there'll be other ideas....
Major Stare
posted on 15/5/06 at 02:00 PM Reply With Quote
Sorry, yes, im trying to remove the bolt.
The other "problem" is, the bottom pulley moving will mean i'll loose my TDC position
Iam using a large breaker bar.
I pressume the bolt isnt a reverse thread?
Jon "FISH"
mookaloid
posted on 15/5/06 at 02:13 PM Reply With Quote
I think the bottom pulley is located on a woodruff key so you shouldn't lose your tdc marks.
Major Stare
posted on 15/5/06 at 02:28 PM Reply With Quote
Silly moment....woodruff key?
Jon "FISH"
Marcus
posted on 15/5/06 at 03:08 PM Reply With Quote
'Peg' on crank, locates into a slot on pullley, preventing rotation.
Marcus
Marcus
Because kits are for girls!!
BKLOCO
posted on 15/5/06 at 07:06 PM Reply With Quote
If the engine is out of the car ie. accessable.
Get a lump of brass/copper/ally against the end of the bolt and hit it bl00dy hard with the biggest hammer you can find.
This should shock the threads and allow you to undo the bolt with relative ease.
Major Stare
posted on 15/5/06 at 08:02 PM Reply With Quote
Engine is currently in and fitted to car but have fairly good access to pulley.
Im out tomorrow to buy one of these.......should work, what do you reccon ?
Jon "FISH"
paulf
posted on 15/5/06 at 09:13 PM Reply With Quote
If its in the car then put it into top gear and get someone to stand on the brake pedal whilst you undo it with a breaker bar and a length of pipe.
Paul.
Major Stare
posted on 16/5/06 at 02:35 PM Reply With Quote
Purchased an electric impact wrench today, took a couple of attempts but it loosened that bolt right off !!!
Jon "FISH"
MikeR
posted on 16/5/06 at 04:25 PM Reply With Quote
cool means my 'proper' one (air powered) should be fine to do the same job then.
let us know how you get on with the trigger wheel - got to do the same at some point.
Major Stare
posted on 16/5/06 at 07:54 PM Reply With Quote
Mike,
Its a doddle, fitted mine to a X-Flow today.
I had to fit two metal spacers with the toothed wheel, so, i used a longer bolt.
Will tighten up in position when the VR sensor is fitted.
Easy
Jon "FISH"
posted on 16/5/06 at 10:29 PM Reply With Quote
Mike,
Easy
How have you keyed it to the crank pulley so it cannot change position?
Major Stare
posted on 17/5/06 at 12:55 PM Reply With Quote
I have bolted it up against the bottom pulley wheel.
I have spoken to a few other people who have done this with no problems.
Jon "FISH"
posted on 17/5/06 at 12:56 PM Reply With Quote
Silly question - but is it a backwards thread? It's a long time since I undid that bolt, but it's backwards on the front pulley/fan of a Pinto engine...
...or did I just imagine that?
Marcus
posted on 17/5/06 at 01:08 PM Reply With Quote
No, it's a normal thread.
The Pinto uses a viscous coupled fan connected to the water pump pulley, not the crank, hence Left hand thread.
Marcus
Marcus
