Author: Subject: MegaSquirt........ Shift light ?
Major Stare
posted on 24/5/06 at 11:21 AM Reply With Quote
Ive heard that a shift light can be wired into the MS?
Is this true and if so how ?
Jon "FISH"
martyn_16v
posted on 24/5/06 at 02:00 PM Reply With Quote
The circiut diagram for the sequential shift light on the MS'n'S-Extra site is missing a diode, you need to place another one in line with the 'high' output of the logic stage, banded end facing towards the transistor stage (same diode as the rest, i used 1N4001's). If you don't put this in you'll probably find the high LEDs stay on dimly all the time.
I grafted mine into the instrument panel of the current wagon (mk2 golf), it's the bottom row of 5 LED's in the centre of the clocks:
Click me for a video of them in action, ignore the diesel-like revs they come on at, was set low for the vid so I didn't annoy my neighbours by bouncing off 7000rpm
[Edited on 24/5/06 by martyn_16v]
stevebubs
posted on 24/5/06 at 02:35 PM Reply With Quote
If you don't fancy jumpering and sourcing all the components yourself, there is a kit with daughterboard that gives this extra functionality.
Available from both Glenn's Garage and Bill Shurvinton for about £30
Major Stare
posted on 24/5/06 at 08:38 PM Reply With Quote
Cheers Steve, it was starting to look a bit beyond me.
Martyn, love what you have done with the LED's
Jon "FISH"
oioi
posted on 28/5/06 at 06:11 PM Reply With Quote
fwiw im using this as a shift light but its not up and running yet
could you do me a favour and answer the q re-tps wiring on the wscc boardroom
cheers
oioi
That is the Curse of Speed which has plagued me all my life I am a slave to it. On my tombstone they will carve,
"IT NEVER GOT FAST ENOUGH FOR ME." - Hunter S Thompson
