Author: Subject: Throttle bodies to flange pipes
piddy
posted on 24/5/06 at 06:45 PM Reply With Quote
When using silicone hose to fit throttle bodies to flange pipes. Can you use standard hose or do you have to get Fluorolined ?
This is a pre SVA installation.
stevebubs
posted on 24/5/06 at 10:59 PM Reply With Quote
standard should be OK. I used filler hose, however.
muzchap
posted on 24/5/06 at 11:02 PM Reply With Quote
I also used fuel filler hose
It might 'fall' off post some testy thing for some nicer looking stuff
A MAJOR CONSIDERATION - where you going to fit you Air Temp Sender
Try to work that out at the same time
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
piddy
posted on 25/5/06 at 03:05 PM Reply With Quote
I'm planning on fitting it inside the air filter somewhere as well as the fidle vale.
muzchap
posted on 25/5/06 at 04:07 PM Reply With Quote
My mate has a tiny little one - he's giving to me at the weekend - it's so small it can be epoxyed in.
I'll have a look at the weekend then post some pics up
Important to get it right, especially with M$ as it adjusts the fuelling.
