Author: Subject: Mega problem
piddy
posted on 28/5/06 at 07:27 PM Reply With Quote
Mega problem
I plucked up the courage to connect my mega squirt to the stimulator and Pc and download mega tune.
I’ll be the first to admit I haven’t got a clue and am beginning to think I shouldn’t have gone the Mega squirt route.
Any way this is what happened.
1st message:
Warning: lambda sensors in 0067- conditional check reference undefined value INNOVATE_ ICI_DEFAULT
Only first reference will be reported.
OK
I pressed OK
2nd message:
Controller code version does not match signature in Megasquirt ini
(See audit log for where the file was found)
Expected “0X14” (found in INI file)
Received “ (from controller)
Table corruption may occur; this is usually a very serious problem
Terminate Mega tune now?
Yes No
I pressed yes.
Any advise what I should do or what went wrong?
Thanks.
rayward
posted on 28/5/06 at 07:49 PM Reply With Quote
sound like your megasuirt is loaded with a different version of map (or possibly firmware), to the software your using.
what software version are you using?,
should be 2.25 really.
Ray
piddy
posted on 28/5/06 at 07:57 PM Reply With Quote
yes mega tune 2.25
tom_loughlin
posted on 28/5/06 at 08:17 PM Reply With Quote
I get the same error message as the second of your two - i guess its something to do with the magatung version (2.25) not being compatible with the software installed on the ecu.
I like the idea of being able to plug the software into a computer - makes you feel kinda professional (even though i havent got the faintest clue what imn doing, i just like to see the dials move
I just hit no (not to terminate the program, and it works ok for me), but saying that, i think ive just managed to break my Ms unit somehow....
Tom
rayward
posted on 28/5/06 at 09:00 PM Reply With Quote
piddy, is your MS just squirt, or has it been modded for suirt n spark/edis??.
tom u2u'd you back
Ray
muzchap
posted on 28/5/06 at 09:50 PM Reply With Quote
Or get ya mate Paul (Doofus) to sort it out for ya
Like I did
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Triton
posted on 28/5/06 at 09:51 PM Reply With Quote
Fit carbies for an easier life.....all this lecy fizzle stuff only goes wrong anyway
www.tritonraceseats.com
www.hairyhedgehog.com
piddy
posted on 29/5/06 at 12:17 PM Reply With Quote
Yes it's been modded for suirt n spark/edis.
Carbs are not an option post 95 engine with cat etc.
