Author: Subject: pinto efi standard injectors
natehall
posted on 9/6/06 at 11:46 PM Reply With Quote
hi - are they low or high impedance?
im going to be using them with megasquirt - and know i need to take it into account
If it aint broke, uprate it
if it is broke, uprate it
http://www.modders-uk.co.uk
BKLOCO
posted on 10/6/06 at 06:19 AM Reply With Quote
As far as I know they are high imp on the pinto.
If you heve a multi meter you can easily check.
12-15 ohms = high impedance
3 - 5 ohms = low impedance
If you dont have a meter I would suggest you go and buy one.
You will almost certainly need it if your installing Megasquirt.
tks
posted on 12/6/06 at 09:04 AM Reply With Quote
mhh
anyway use high impedance ones (high coil resistance) else megasquirt will need to work with PWM and thats a pain in the axxx..
Tks
BKLOCO
posted on 12/6/06 at 07:10 PM Reply With Quote
Tks
Not necessarily.....
There are distinct advantages to running low imp injectors...
you do not need to compensate for the "mechanical lag" associated with high imp units.
PWM isn't that tricky to get to grips with when compared to all the other parameters in MS setup.
You can also fit ballast resistors. Although this will negate the benifit stated above.
tks
posted on 13/6/06 at 12:42 PM Reply With Quote
mhh
using high consuming power injectors
has also bad thing like more warmth in the injector sow the fuel will get warmer.
also it isn't entirely true because the limits are still there.
If megasquirt uses fets to accept 12ohm minimum..
It means that they can handle 1Amp max.
the same fet could have a max rating of 30amps butmaybe only for a small duration and thats where the pwm trick falls in.
sow in fact you arent entirely using your
48Watss injectors (3ohms) (you never will use 100% pwm signal wich is the same as a normal injector.
also there is always time needed to open en close the injector. altough i recon that a 3ohm (at full pull) will be faster as normal one.
am i right?
Tks
BKLOCO
posted on 13/6/06 at 02:23 PM Reply With Quote
That's the whole point of low imp injectors.
You apply full voltage to "snap" the injector open quickly. The driver will not maintain this current so the system applies Pulse width modulation to reduce the effective current but still hold the injector open for the prescribed fuel pulse.
tks
posted on 14/6/06 at 12:25 PM Reply With Quote
Sow,
you say that while open it
it uses 100% pwm signal and after nothing (very small amount of time) it starts pulsing the fet.
Could be true and sounds reasonable...
bike injectors are also fast!
Tks
sebastiaan
posted on 15/6/06 at 05:03 PM Reply With Quote
They are high impedance. What engine are you megasquirting?
natehall
posted on 16/6/06 at 08:52 AM Reply With Quote
A 2.0 Pinto, was originally carbed but am shoving a EFI head on it to make sure its unleaded proof
whilst i was shoving it on - i realised i understand moreabout fuel injection and EDIS than i do about carbs and points dizzy, and the megasquirt idea came to mind, just getting all the info together at the minute whilst i finished the mechanical bits then will start to aquire the parts to get a MS install going
sebastiaan
posted on 18/6/06 at 06:18 PM Reply With Quote
If you run into problems, let me know. I'm running MS on a pinto in my MK. Modified plenum, original ignition (for now), MS1 extra in fuel only mode. Dead easy to set up....
natehall
posted on 19/6/06 at 03:45 PM Reply With Quote
/quote]
dont suppose you could email me a copy of your setup as a base - im going to go for spark control as well
