stevebubs
posted on 10/6/06 at 12:30 AM |
Gixxer TB Springs
Any tips on making the TBs close quicker and more tightly? Guessing I'll need to stiffen or add springs....just wondered if anyone had tackled
this problem already
Guinness
posted on 10/6/06 at 06:26 AM |
My bike carbs have provision for two cables, one to pull open and one to shut them off, as well as the springs.
If the Gixxer T/B's are the same could you not attach a bike brake cable to the return side with a big spring fixed to the chassis?
HTH
Mike
posted on 10/6/06 at 08:28 PM |
If the TB's aren't closing fully that's nearly always a sign that something is binding e.g. bent spindle or sticky bearing.
stevebubs
posted on 10/6/06 at 08:39 PM |
They do close but it's sometimes a little "sticky" and takes a second or two to close itself.
Also gonna relube the spindles on them and see if it helps
It wasn't doing this last year and I haven't changed anything since.
[Edited on 10/6/06 by stevebubs]
stevebubs
posted on 11/6/06 at 05:30 PM |
OK..Tracked the problem down to sticky Throttle Cable.
Removed, relubed and put back together.
All sorted.
