mr zefect
posted on 24/6/06 at 09:06 PM |
Ms probs
I am having probs with my car when at stedy rpm say 4000 the engine feels like someone is shuting the fuel on and off making the car jurk but is fine
at higher rpm and is ok at low rpm say 1500 to 2500 im runing msnspark 2.2 with edis and on a 20l zetec running gsxr 750 throttle bodys and new range
rover pump i thought it might be spiking but i have shilded wire going from the realy board to edis the only thing i dident was from the ms to realy
board so i tryed puting some in but when i earth out the xg1 out side the board it wont start has anyone got any ideas thanks chris.
mookaloid
posted on 24/6/06 at 10:15 PM |
Hi Chris,
No idea about the answer to your problem, but if you used some punctuation it might be easier to understand the question.
Anyway have a prize for the longest sentance I have seen for some time
Mark
martyn_16v
posted on 25/6/06 at 09:09 PM |
Probably a bit too lean at that site on the map, try richening it up a touch. As mentioned above, datalogs are your friend, take one of it during the
problem to confirm what is happening
mr zefect
posted on 27/6/06 at 08:49 PM |
Thanks for the advice i had a play with another map i had and it seems to have sorted it.
