Author: Subject: Fuel balance pipe - solid or rubber?
RazMan
posted on 6/7/06 at 09:08 AM Reply With Quote
I've got two fuel tanks (one in each side pod) which require a 8mm balance pipe so that the pump can draw from both tanks. The pipe needs to be mounted very low down and P clipped to the bottom chassis rail.
As it will be potentially at risk from contact with road debris, speed bumps etc, is it best to make it from solid copper or braided hose? The prospect of watching 8 gallons of fuel dribbling out is a little disconcerting!
Raz
andyharding
posted on 6/7/06 at 09:12 AM Reply With Quote
Regardless of material but a tap at both ends then if it does get damaged you can isolate the tanks to stop a leak and while you replace the pipe!
RazMan
posted on 6/7/06 at 09:25 AM Reply With Quote
Excellent advice Andy - I'll do that
Raz
Bluemoon
posted on 6/7/06 at 09:30 AM Reply With Quote
Could you not mount the pipe on the back of the chassis tube i.e not on the foward facing side, thus offering a little protection?
Dan
tks
posted on 6/7/06 at 09:43 AM Reply With Quote
yeah
anyway i woulf first weld a 20mm stainless tube untherneath if you cant reroute it.
in case a stone hits it then the tube will deform and you are warned with a glong that you have hitted something..
in ohter cases you will just drive further with out notice
i would go rubber and a stainless extra tube untherneath..
the rubber can deform sow in case of a collision it wont drippele fuel.
the tube is there for high priority protecion..
Tks
Danozeman
posted on 6/7/06 at 11:08 AM Reply With Quote
I would weld a tube onto the rail and run a rubber pipe through that for protection. Then as Andy said taps at each end just incase.
Dan
RazMan
posted on 6/7/06 at 11:14 AM Reply With Quote
The balance pipe has to 'wiggle' round a couple of brackets on its route so I can't weld a straight pipe to the chassis as protection - excellent suggestion though.
Raz
tks
posted on 6/7/06 at 11:27 AM Reply With Quote
huh?
wy not?
just weld the parts/ that are facing the ground...
you are not very clear on your situation..
You even could just weld up an complete tube and take away with the angle grinder the pieces where the hose needs to enter or exit the tube...
TKs
RazMan
posted on 6/7/06 at 12:50 PM Reply With Quote
I see what you mean but I should have mentioned that I am replacing an existing pipe which has deteriorated by the fuel - despite having a spec sheet to say that it is proper fuel pipe for the job I am therefore reluctant to start welding on pipes next to my fuel tanks and spoiling my powder coated chassis in the process.
I have decided to use P clipped 10mm Kunifer pipe along with an isolation valve on each tank in case of any problems.
Thanks for all the help guys
Raz
