Author: Subject: Engine Dyno
lsdweb
posted on 28/7/06 at 01:06 PM Reply With Quote
Engine Dyno
Hi All
I've just spoken to the guy who I was hoping would do the rolling road session on my single seater for me. He's very reluctant to do it as he doesn't think the car will be able to keep cool enough because of the position of the radiator.
He's suggested that I go to a dyno specialist instead (and recommended somebody in Exeter). I've never been to a dyno before so I'm a bit confused on what to expect so, before I phone the guy, can anybody explain how it works - I understand the priniciples but it's the practical bits I don't get! Like, if I take only the engine, injection, exhaust etc. will I have to make up a new temporary loom to wire in my ECU?
Regards
Wyn
posted on 28/7/06 at 01:24 PM Reply With Quote
hmmm, interesting; is getting some long hose and connecting to another radiator outside of the car? it is not like the cars is going to move very far, well not if all goes to plan
DarrenW
posted on 28/7/06 at 01:59 PM Reply With Quote
Surely the rolling road people will be able to direct the fan in roughly the right location or use 2????? They could always keep an eye on the vitals and abort if they get nervous about it.
posted on 28/7/06 at 02:02 PM Reply With Quote
Are you suggesting that you need to remove your engine and ancillaries to get the engine on a Dyno or am I reading it wrong? A Dyno is just an abbreviation for dynamometer which is a device used to measure and adjust an engine’s horsepower and performance. There are numerous places that do this for CEC’s but few that have the capability to adjust a bike engine in a car application.
The few that I know of are Holeshot Racing, TTS and PDQ. When we took ours to Holeshot, they placed a large fan in front of the nosecone to force feed cool air whilst measuring and adjusting the performance via the Dynojet Power Commander. I assumed that this was standard practice, so I don’t suppose it matters where your rad is, as long as they can get cool air into it to prevent your engine overheating.
Phil
SeaBass
posted on 28/7/06 at 02:53 PM Reply With Quote
A rolling road Dynamometer is used for comparative setup and tuning ideal for cars. Torque is measured at the wheels then drivetrain losses & inefficiency is estimated and a calculation is done to provide an estimation of BHP and Torque for the engine. If you use the same Dyno every time or if 'live' tuning and mapping is taking place fine. Beware that different Dynos provide different output figures due to the estimation in calculations...
An engine Dynamometer is used for testing and engine development usually by engine builders and manufacturers. Readings are taken from the flywheel in car applications - unknown for a bike??. Probably not what your looking for.
ned
posted on 28/7/06 at 03:10 PM Reply With Quote
Philspeed (build a lot of sports2000 race engines - i believe they're in/near torquay) have an engine dyno, I know someone who's had their engines on his over the years.
beware, I've got yellow skin
davidwag
posted on 28/7/06 at 06:51 PM Reply With Quote
hi,
I'm in Exeter but didn't know of anyone round here with a dyno.
Whats their name?
What type of engine are you running?
And what management?
Unless the dyno guy does that type of engine and that type of management system you will probably need to provide a wiring loom.
lsdweb
posted on 28/7/06 at 08:57 PM Reply With Quote
Hi All
I've spoken to the engine dyno chap - Rob 01769 STD - he can't do it either - he doesn't have the correct brackets and exhaust for an R1 so it would be far too difficult / costly to set it all up.
He's suggested I go to Emerald which would have been my first choice only it's 450 miles away!
Regards
Wyn
stevebubs
posted on 28/7/06 at 10:33 PM Reply With Quote
Have a chat with the guys in Oxford recommended by Emerald - a bit closer...can't remember their name off the top of my head.
