Author: Subject: Would this work as a fuel rail?
Major Stare
posted on 6/8/06 at 09:43 PM Reply With Quote
Would this work as a fuel rail for my MegaSquirt install?
CLICKY HERE
Jon "FISH"
posted on 7/8/06 at 12:16 AM Reply With Quote
Looks like it's for a specific Honda SOHC engine so likely already drilled for the injectors.
posted on 7/8/06 at 06:35 AM Reply With Quote
take a look in B&Q - they sell aluminium tube and box section is differening sizes; a bit of lumiweld to block of the ends and attach other aluminium stuff would work just as well; andf if you really fancy it, try try DIY anodising.
posted on 7/8/06 at 06:36 AM Reply With Quote
matt_claydon
posted on 7/8/06 at 07:17 AM Reply With Quote
That will have holes for injectors already drilled so no good for you unless the spacing happens to be perfect. Demon Tweeks sell blank fuel rail but it's not cheap.
Major Stare
posted on 7/8/06 at 08:16 PM Reply With Quote
Not heard of Lumiweld?
Have also contemplated using copper but cant see how i can fit unions to accept fule in and out of the fail???
Jon "FISH"
NS Dev
posted on 8/8/06 at 07:58 AM Reply With Quote
ah now that's dead easy, 15mm to 8mm microbore solder ring reducers! available from your local B&Q or screwfix.
