Author: Subject: MegaLogViewer
BKLOCO
posted on 10/8/06 at 12:16 PM Reply With Quote
MegaLogViewer
All I can say is WOW!!
What a great program.
Won't make much sense to anyone not running and trying to tune MegaSquirt but if you are I can recomend this program.
It allows you to examine all aspects of a captured log file and re-run it graphically in real time on your laptop whilst viewing the VE and Timing tables.
Also analyses your VE table against your AFR and tells you by what % you are hi or low of the targets in each bin.
Brilliant.
Oh and it looks the dogs danglies to anyone looking over your shoulder as well
posted on 10/8/06 at 12:35 PM Reply With Quote
paulf
posted on 10/8/06 at 08:56 PM Reply With Quote
It is a very good application and can show lots of info relating to the engine and fueling, I used it to get my fuel map somewhere near right fairly quickly.
I havent had any luck with Megasquirt tweak 3000 however as i couldnt get it to open the files correctly, so gave up and just tuned from datalogs manually.
Paul
