Rich_T
| posted on 29/8/06 at 10:29 AM |
Tubular Alloy Plenum
Further to my earlier post in the engine forum, Im quite fancying a tubular alloy plenum chamber on my Silver top Zetec. Is there any pre requirements
regarding volume and/or airflow or would (in its most basic form) a sealed alloy tube connected to the throttle body with an outlet to the air
filter.
Your thoughts and ideas appreciated on this.
Schrodinger
| posted on 29/8/06 at 11:36 AM |
I used to have one from a Ginetta and the tube was about 100mm diameter if that helps
Anglia66
| posted on 29/8/06 at 12:03 PM |
Ideally the plenum chamber should be at least the same capacity as your engine with each inlet tract being the same capacity as one cylinder.
BKLOCO
| posted on 29/8/06 at 01:02 PM |
You mean something like this?
  Description plenum off car 1
  Description plenum off car 2
  Description plenum on car 1
BKLOCO
| posted on 29/8/06 at 01:04 PM |
Rich_T
| posted on 29/8/06 at 01:43 PM |
I meant something exactly like that. Thanks, thats just the info I needed!!
