Author: Subject: Bosch Fuel pump
piddy
posted on 2/9/06 at 06:16 PM Reply With Quote
Bosch Fuel pump
Hello all.
The bosch fuel pump I have has a large exit and a small exit. Is the large the supply to the pump and the small the exit or vise versa?
Also if the wiring is connected the wrong way around would the pump work in reverse?
iiyama
posted on 2/9/06 at 06:18 PM Reply With Quote
probably got a large inlet and small outlet. Outlet is normally around 8mm id. Inlet around 12mm id. Outlet generally has the terminals either side of it too.
piddy
posted on 2/9/06 at 06:43 PM Reply With Quote
This one has the terminals either side of the 8mm.
[Edited on 2/9/06 by piddy]
piddy
posted on 2/9/06 at 08:20 PM Reply With Quote
Cheers that was what I was thinking.
unfortunatly I have connected it up the wrong way.
