theohighland
posted on 12/9/06 at 04:19 PM |
dohc running bike carbs
does anyone know if its possible to set up a 2.0l DOHC to run on bike carbs?
If it is possible, is it any better/cheaper than using twin webers?
Cheers, Theo
jacko
| posted on 12/9/06 at 05:08 PM |
Hi i don;t see why you cannot use bike carbs there better then webers in my opinion [ now i run for cover] i have bike carbs fitted to a pinto and i
think there brill just set them up and forget them unlike webers Jacko
Fatgadget
| posted on 12/9/06 at 05:27 PM |
As an aside.why is it that Webers go out of tune?..Is it the throttle linkage or what?
Phil. S
| posted on 12/9/06 at 07:13 PM |
I'm interested in this. I have a Vauxhall 20XE on Weber 40s which gets me around175bhp and plenty of torque. But they run a little rich between
3,000 and 4,000rpm, and it drinks fuel at an alarming rate. Would bike carbs be better? I've heard the carbs from a Honda CBR1100XX Blackbird
make a good fit.
"The unexamined life is not worth living" (Socrates)
"The unlived life is not worth examining" (Kopp)
jacko
| posted on 12/9/06 at 09:25 PM |
Phil i think the answer is yes i have had no trouble at all with my zx9r bike carbs god fueling ect Jacko
Schrodinger
| posted on 13/9/06 at 09:45 AM |
Having run a car on both Carbs and TBs I would suggest that when set up correctly the biggest advantage of TBs is the smoothness of the power
especially at light throttle and the fuel ecconomy over carbs
PaulBuz
| posted on 14/9/06 at 03:37 PM |
Yes its possible, but you'll have to make a manifold!
Paul
