John P
posted on 25/9/06 at 10:14 AM |
EDIS - Do I need the cable?
I've been looking for an EDIS unit for my Megajolt and although some e-bay ads say they include cable others don't.
Is it important to have a length of the original cable or can I re-wire the plug myself?
Also what would you expect to pay?
graememk
posted on 25/9/06 at 10:22 AM |
get the cable i think its easier to get them wired up then
martyn_16v
posted on 25/9/06 at 11:38 AM |
The important one is the cable to the VR sensor, it needs to be properly specced and constructed shielded cable to provide some insurance against the
teeny signal from the sensor being wiped out by the many potential interference sources in the engine bay. You can make it yourself, but it's
easiest (and cheaper) to just get it from a Ford loom at the scrappy.
posted on 25/9/06 at 03:11 PM |
Do you already have a plug? Unless you've managed to source a new one it will have been chopped off a loom, hence will have some wires already
attached. The longer the better really as trying to get a reliable splice onto short stubs is a PITA.
John P
posted on 25/9/06 at 03:22 PM |
Thanks for the advice.
I don't have an EDIS unit at present but have realised that a number of the ones on e-bay seem to have been cut off flush with the plug.
I think I'll make sure I get one with cable to avoid any potential problems.
graememk
posted on 25/9/06 at 05:05 PM |
u2u bigwaza on here as he takes every one he finds when he visits the scrap yard
ZetecVan
posted on 29/9/06 at 07:15 PM |
The one I got off ebay had the plug but the wires were cut after about 2 inches. Wiring it up to the megasquirt was no problem though.
Mal
posted on 29/9/06 at 07:36 PM |
Ford VR Sensor Leads
Not all Ford VR sensor leads in Ford looms are screened. In my Escort Zetec loom, circa 1993, the VR sensor lead to the Edis was not screened, but the
PIP and Saw wires, going from the Edis to the ECU were.
Mal
