scutter
posted on 26/10/06 at 06:01 PM |
How to mount trigger wheel?
To be honest, I'm stumped. How can i mount a trigger wheel to my Ali bottom pulley? The main problem is that the bolt is recessed.
Any answers/soloutions would be gratefully recieved.
ATB Dan.
[img][/img]
flak monkey
posted on 26/10/06 at 06:02 PM |
Make a spacer on the lathe and get a longer bolt?
Sera
http://www.motosera.com
marc laptop
posted on 26/10/06 at 06:03 PM |
is there room to bolt it behind the pulley ??? just done the same for a mate on his v8 engine, machined out the trigger wheel and bolted through the
back
best regards
marc
big_wasa
posted on 26/10/06 at 06:07 PM |
See Link Oh and if you havnt got one yet? I have a new one with sensor that I decided not
to use
paulf
posted on 26/10/06 at 06:34 PM |
I would turn a register on the wheel to fit into the pulley centre bore and then with it located drill and tap six 3 or 4 mm holes through the wheel
into the pulley and secure it with cap screws.
Paul.
scutter
posted on 26/10/06 at 06:37 PM |
Outstanding gentleman, knew i could rely on you.
Aother cheeky question, does anyone know that the threads are for the front pulley bolt and timing gear cover on a crossflow?
ATB Dan.
