Author: Subject: Are all VR sensors the same...?
PeterW
posted on 1/12/06 at 10:26 PM Reply With Quote
Evening...
Due to 'connections' to the auto parts industry, I've been offered a quantity of Volkswagen VR sensors if they are of any use for Magajolt.
Are VW sensors the same as Ford ones, or do I need to use a Ford one with an EDIS unit..?
Peter
Fatgadget
posted on 1/12/06 at 10:44 PM Reply With Quote
I suspec a VR sensor is a reluctance transducer. Its job basically is to detect the presence or absence of something indusive.
I would say no difference.
Dusty
posted on 2/12/06 at 12:46 AM Reply With Quote
Magnetic Variable Reluctance with either standard or high output and that needs to be factored into the hardware. My Omex ECU uses a jumper setting for the output of the sensor.
