bigrich
posted on 5/12/06 at 10:22 PM |
push button gearshift
is anyone using a push button gearshift system on there bec
i'm considering fitting one with ignition cut to my new build but would like some feedback b4 spending th cash
i've so far looked at klicktronic, proshift and a race gadgets pnuematic system any opinions or other sugestions
cheers bigrich
tegwin
posted on 5/12/06 at 10:28 PM |
I dont imagine it would be to complex to design and build your own to be honest...Encorporate a gear indicator whilst you are at it and any other
funky bits that you fancy...
Deffinately cheaper..depends on your skills though
I would have said that the Pneumatic one would be far more precise and faster than an electric one.....and in a car the size of the compressor isnt
going to be an issue..
Dunc
[Edited on 5/12/06 by tegwin]
sparrks
posted on 5/12/06 at 10:44 PM |
http://www.translogicuk.com/ps1.htm what about this one
have a look at the dash aswell
[Edited on 5/12/06 by sparrks]
mike smith1
posted on 6/12/06 at 11:12 AM |
mk blade (Tony) uses the pro shift, looks very impressive i'm sure he will provide you with some very good feedback.
Mike
TimC
posted on 6/12/06 at 01:52 PM |
I'll be using Kliktronic. Seen it used to good effect on a Megabird and a ST Locoblade.
TC
scotlad
posted on 6/12/06 at 02:43 PM |
I've got kliktronic on mine with the ignition cut. works a treat too
TimC
posted on 6/12/06 at 03:33 PM |
Have you used it without the ignition cut?
If so, what's the big benefit?
smart51
posted on 6/12/06 at 04:07 PM |
Ignition cut turns off the spark, killing the power. This unloads the dogs on the gears alowing a clean shift without knackering the gears.
ch1ll1
posted on 6/12/06 at 06:50 PM |
i have the klicktronic on mine
swmbo says there spaz buttons
worked well on the zx9, but havent got around to fitting them on the blade yet !
but soon
once you have it set up right its great,
but its alot messing at first !
if the price is right i might even sell them !!
only been used for 500 miles ! if that !
[Edited on 6/12/06 by ch1ll1]
tks
posted on 12/12/06 at 05:08 PM |
mhhh
I made my own with RC servo´s
i have everything electric.
Clutch
Throttle
Gearchange..
Have incorporated the cut the power to coils and injectors but didn´t fancy connecting it yet.
first i need OTR etc. etc..
Tks
tks
posted on 15/12/06 at 07:45 AM |
I refer to this units...
LINK
Titanium gear alloy!
3Amps at 6volts = 18Watts..
23Kg/Cm
The gearbox lever needs peaky torque
Sow i used one 5Amp regulator at 6volts for that one.
You will need electronics to steer the servo. (Microcontroller)
Tks
