Author: Subject: GSXR Injectors - Info needed
TangoMan
posted on 16/12/06 at 01:21 PM Reply With Quote
Info needed.
I have scanned the web anf various forums to source info for my GSXR injectors.
It appears that the flow rate is 270cc/min but at what pressure. (I also read that they are only 240cc/min!! )
I also need to know if they are High Impedance or Low Impedance as I need to set up my Megasquirt for them.
Any info would be appreciated.
MS sorted
Innovate LC1 sorted
Engine and required bits sorted.
TB's sorted
Inlet manifold still to source. I bought a manifold flange of eBay but after paying it has not been sent. The user is no longer registered
Exhaust manifold is currently in the form of lots of pipe bends and a flange.
Hoping to be all sorted for spring.
Summer's here!!!!
trikerneil
posted on 16/12/06 at 01:42 PM Reply With Quote
According to my GSXR600 (2001/2002) the fuel pressure should be 43psi.
Don't know about impedance though.
ACE Cafe - Just say No.
TangoMan
posted on 16/12/06 at 02:53 PM Reply With Quote
Thanks CaLviNx.
I have calculated that if they are 240cc/min @ 43psi then with 54psi I can get them up to 270cc/min which should be good fro 175bhp.
Does that sound right??
Summer's here!!!!
Dusty
posted on 16/12/06 at 05:19 PM Reply With Quote
Mine were a deep red colour and supposed to be 275cc/min at 3bar, high impedance from a 750 GSXR.
[Edited on 16/12/06 by Dusty]
TangoMan
posted on 16/12/06 at 07:08 PM Reply With Quote
It may depend on year then as mine are definitely black.
I will have to test them for flow rates once I have the set-up running. 275psi would be good as it would leave some scope for tuning next year.
Summer's here!!!!
posted on 17/12/06 at 02:41 PM Reply With Quote
My GSXR1100 injectors have 2 ohm resistance Takes just a few seconds to measure them .
posted on 17/12/06 at 03:58 PM Reply With Quote
2 Ohms measured with a decent multimeter . Checked them all Thursday evening and all the same.
omega 24 v6
posted on 17/12/06 at 04:38 PM Reply With Quote
2 ohms is very nearly a direct short to earth. Your prolly gonna have a hell of a current passing through the coil
posted on 17/12/06 at 05:14 PM Reply With Quote
I suspect that after nearly 40 years in the motor trade i have some idea how to use a multimater!
posted on 17/12/06 at 07:30 PM Reply With Quote
I quote from Dave Walkers book on engine management page 73 . Very early electronic injection systems used low impedence coilswith a resistance of ABOUT 3 ohms Think he knows a thing or two about injection systems!
chriscook
posted on 17/12/06 at 10:48 PM Reply With Quote
Forgive me if I'm wrong but rusty nuts is only talking about his injectors NOT all GSXR injectors. And seems to be suggesting that Tangoman might want to measure the resistance of his injectors...
posted on 18/12/06 at 07:14 PM Reply With Quote
I have made a cock up. My throttle bodies are from a Kawasaki GPZ? 1100 , Sorry for any problems caused .
TangoMan
posted on 19/12/06 at 12:07 AM Reply With Quote
See, it's good to have a healthy debate!!!
This forum is as entertaining as it is informative.
[Edited on 19/12/06 by TangoMan]
Summer's here!!!!
