Author: Subject: upgrade warnings
mr zefect
posted on 14/1/07 at 11:17 PM Reply With Quote
upgrade warnings
I have just updated my ms codes from 2.25beta and extra 0245 to mt225p1 and o29t but when i click on my ms icon i get 6 or 7 warnings then if you just click through them it starts up fine has any one got any ideas how to sort this prob out im using ms 2.2 on edis on led 17.
CairB
posted on 14/1/07 at 11:38 PM Reply With Quote
The msns-extra.ini (or equivilent) file needs to match the firmware version.
This is when you get the warnings that you describe.
eg for 021s you would rename msns-extra.ini.021s to msns-extra.ini then adjust for your configuration.
mr zefect
posted on 14/1/07 at 11:59 PM Reply With Quote
I was told to down load the 029t firmware and down load the latest 2.25 version i am a bit thick when it comes to firmware etc im only updating it for my new Lc1 wide band sensor they should do a ms hand book for thickos like me.
CairB
posted on 15/1/07 at 09:41 PM Reply With Quote
I think that this can also be caused by using a USB-Serial cable without changing the settings. The details are on the MS site.
