nitram38
posted on 15/1/07 at 04:25 PM |
Anyone used one of these?
LAMBDA GAUGE
Will I be able to get my CO down using this (planned R1 + Cat) or will I still need an exhaust gas analyser for the final c/o ?
ecosse
posted on 15/1/07 at 05:14 PM |
Doesn't the gauge just provide a reading, rather than being responsible for changing or adjusting the mixture?
Alex
nitram38
posted on 15/1/07 at 05:34 PM |
Forgot to say that I have a power commander and laptop for that and it is an injection engine.
[Edited on 15/1/2007 by nitram38]
ecosse
posted on 15/1/07 at 07:15 PM |
Ahh..makes sense now
from what I understand of it the gauge would allow you to see what effect the changes made to the map (via the commander) were affecting the mixture,
is that what you were trying to achieve?
Looks like a good option to me, if the gauge wasn't so costly it would now be high on my list
Alex
nitram38
posted on 15/1/07 at 07:19 PM |
It is a high price, but a couple of rolling road sessions would wipe that out.
My thinking is that the gauge might give you the correct running setup, but what about CO emmissions beyond the cat?
The lambda will be installed before the cat.
I would like to have two maps. One for SVA and the other for road. Maybe even a 3rd for trackdays.
ecosse
posted on 15/1/07 at 07:40 PM |
Good point on the RR sessions, I always forget about that cost.
As for emissions beyond the cat, if the cat is good and the mixture is correct, there should be no problem, especially as you could have a map for
"economy" which would ensure a good result on the test!
Your gauge has now moved up my list a bit
Alex
nitram38
posted on 15/1/07 at 10:47 PM |
Just found a £75 cheaper version
CLICKY
ecosse
posted on 16/1/07 at 12:01 PM |
Nice one, it's getting interesting now, I see this one can include a temp sensor as well, that amounts to a lot of useable info for setting up
and monitoring an injection system
Alex
