Author: Subject: Electronic Fuel Level sender
Jonte
posted on 4/2/07 at 08:05 PM Reply With Quote
I´m trying to find a electronic fuel level sender for my tank. The model I´m looking for is just a pipe without any moving parts.
Anyone seen something like that?
Click it
rayward
posted on 4/2/07 at 08:55 PM Reply With Quote
ETB instruments...
POA though so could be expensive!
Ray
nitram38
posted on 4/2/07 at 09:47 PM Reply With Quote
It still has moving parts, there is a float inside the tube !
Chippy
posted on 4/2/07 at 11:01 PM Reply With Quote
They are used in the marine industry. And they come in several lengths, plus I think you can cut them to fit. Try "ASAP" they have a web site, may be of use. HTH, Ray
Added this is ASAP site, look for DIP fuel tank sensor
[url=http://www.asap-supplies.com/]
[Edited on 4-2-07 by Chippy]
craig1410
posted on 4/2/07 at 11:13 PM Reply With Quote
I used one of the "S2" senders from the following site:
http://www.tek-group.co.uk/acatalog/Fuel_Senders_.html
They are fairly expensive but there are no moving electrical parts (other than the reed switches closing as the magnet on the outer ring moves past them. This type of design is supposed to be very reliable. Too early yet for me to tell...
Craig.
bimbleuk
posted on 5/2/07 at 11:02 AM Reply With Quote
Have a search for capacitive fuel senders. I was looking for something similar but went for the above VDO dip tube as the cost was reasonable and Merlin Motorsport just happended the have the exact length I wanted when I asked.
Big advantange of the sealed dip tube is you can use the foam baffle bricks for track work.
