les
posted on 22/2/07 at 11:03 PM |
fuel line connections
hi,
I have a solid fuel line running down the length of the transmission tunnel,
can I connect the fuel hose directly to this?
or does it need some type of fitting on the pipe?
les
NeilP
posted on 22/2/07 at 11:08 PM |
You can go mad with aeroquip if you want but a little flare on the end of the pipe, a touch of fairy liquid, grunting and a couple of hose clips
(tightening in opposite directions) should do you fine - Done this on mine with a 7.5 bar pump and never had a leak yet...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
les
posted on 22/2/07 at 11:13 PM |
thanks,
sounds like its ok- I have the hose pushed directly on, with a hose clip,
will add a secons to each joint
cheers
les
Chris_G
posted on 23/2/07 at 12:07 AM |
If you are using copper lines you can solder on an olive to each end to act like a flare which is what I did and it was very simple but worked
brilliantly.
Chris
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
martyn_16v
posted on 23/2/07 at 10:07 AM |
I've seen OEM setups that have the flexi-pipe pushed over an un-flared hard pipe end and then jubilee clipped on, so anything more substantial
than this should be more than OK
