Author: Subject: Parallel thinking and turbos
RazMan
posted on 25/2/07 at 09:30 AM Reply With Quote
Bit of a cheesy video but what do you think of this turbo setup? It might overcome some common problems like space & under bonnet temperatures.
Link
[Edited on 25-2-07 by RazMan]
Raz
graememk
posted on 25/2/07 at 09:55 AM Reply With Quote
they make it look so easy lol
bilbo
posted on 25/2/07 at 09:58 AM Reply With Quote
I think this sort of system has been looked at before on here. The main problem I can see is the large distance from the compressor to the inlet, which means a lot of air volume to compress, which means laaaaag.
Do like the video though. Remember 'Tool Time'?
[Edited on 25/2/07 by bilbo]
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
nib1980
posted on 25/2/07 at 10:02 AM Reply With Quote
sweeettt
daviep
posted on 25/2/07 at 10:03 AM Reply With Quote
Not the best setup for maximum power. Too much heat will be lost from the exhaust gasses between the engine and the turbo.
MikeR
posted on 25/2/07 at 10:20 AM Reply With Quote
daft question - the last bit they show they says "what turbo lag"
How come?
Is it a case of small turbo with large displacement engine meaning it spins up quickly all that way down the exhaust?
(ie i'm confused and can't understand why they don't have massive lag)
jlparsons
posted on 25/2/07 at 10:35 AM Reply With Quote
Turbo lag - what turbo lag?
Notice the lack of any argument, comparrison or qualifier in such a small statement for such a big issue. Don't infomercials rock?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
RazMan
posted on 25/2/07 at 10:46 AM Reply With Quote
Surely it is actually better that way - it's not the heat which makes boost - purely movement of the gas which powers the turbine..... or am I missing something?
Regarding the lag argument, I can't see how they can claim 'what lag?' with pipes that long. They do mention a loss of 1 psi but that doesn't make much sense either.
Raz
Moorron
posted on 25/2/07 at 11:35 AM Reply With Quote
didnt watch it all but am i right in saying they mounted the turbos at the back of the car? . are they mad.
its been said already but lag and heat are the isues.
But it is from the usa. Think of all the car adds oer there for there sport cars, which never mention anything other than what bhp and straight line speed they can do.
dumb americans, dumb idea.
Sorry about my spelling, im an engineer and only work in numbers.
scottc
posted on 25/2/07 at 12:44 PM Reply With Quote
At least if the labour is charged by the hour, its only gonna cost 1/2 hour for installation.
I wish every job I did on a car went that smoothly.
posted on 25/2/07 at 01:32 PM Reply With Quote
What turbo lag?
Like it wouldn't have spun the wheels when it "only" had 343bhp Remember Tool Time? I still watch it on ABC1
MikeR
posted on 25/2/07 at 02:17 PM Reply With Quote
From my limited understanding, the heat issue is ...
hot gass takes more volume, therefore as it cools it will slow down.
This is countered by the compressor side of the turbo heating up the inlet gas, this will also get cooled as it runs to the engine - which they mention.
I wonder if having such a long inlet run does cause lag but puts the lump of air in much more gracefully. I'm thinking its more of a "whoohoo" as the turbo spins up instead of "oh my god whoohooo". Then again they took a 350hp engine to (can't quite remember) 500hp?
CraigJ
posted on 25/2/07 at 03:27 PM Reply With Quote
with pipes that long you WILL get lag no matter what.
MikeR
posted on 26/2/07 at 06:40 PM Reply With Quote
The point i'm trying to make is - you will have lag, but in a 'normal' installation the lag is generally accepted to be a big "Whump" as the extra air hits the engine.
With such a long pipe I'm wondering if the "whump" is more gradual so you get lag, but it manifests itself as a gradual (in relitive terms) increase in power so is less noticeable.
Simon
posted on 26/2/07 at 08:39 PM Reply With Quote
And, of course, with that much compressed air sitting in a pipe as the throttle is closed
Oh yeah, it's got a dump valve.
Wonder if they do one for the Mustang engine (in the ZT)
Simon
