Dave Bailey
posted on 6/3/07 at 10:11 PM |
Fuel tube and clips
Anyone know if you can use nylon or similar for fuel tube in the transmission tunnel. I am also trying to find some of the push in clips for 8mm pipe.
I have these for the brake lines but can't find any for the fuel lines. It would be even better if I could find some dual ones so that I can run
the fuel pipes together.
Any help appreciated.
thanks
Dave Bailey
posted on 6/3/07 at 10:23 PM |
I've used some plastic fuel pipes through the tunnel on mine but it's a carbed engine and only low pressure . A lot of modern cars use
plastic high pressure fuel lines
