Steve Lovelock
posted on 25/3/07 at 12:01 PM |
Where do I put the MSnS
Just about finished the soldering and now turning my mind to where I should put the unit in the car. I know I want it under the scuttle but not sure
where would be best. Has anybody got a picture of their installation in a seven type car for me to look at please?
CairB
posted on 25/3/07 at 05:18 PM |
I mounted mine behind the aluminium dash using velcro as this helps to isolate it from the vibration and for ease of removal.
Steve Lovelock
posted on 25/3/07 at 08:21 PM |
Velcro, doesn't it fall off when you go over speed humps?
CairB
posted on 25/3/07 at 09:17 PM |
No, but my sump gets dented
Or, no the velcro doesn't fall off because I glued it on adequately.
It is all down to how much velcro and where you fit it.
I have 2off, 25mm strips along the edges of the long face of the enclosure.
I found that I had to mask some of it to enable it to be removable easy enough, but without if falling off over speed bumps of course.
JAG
posted on 28/3/07 at 01:15 PM |
My ECU is mounted at the bottom of the passenger footwell with a panel over it to protect it from clumsy feet
Justin
