Author: Subject: Mega squirt question
piddy
posted on 6/4/07 at 02:45 PM Reply With Quote
Those with Mega squirt.
What does the KPA show when you turn on the ignition?
tks
posted on 6/4/07 at 02:49 PM Reply With Quote
it should show then the barrometic pressure!
sow depending on the weather / altitude
it should show around 1Bar
MegaSquirt samples that sensor once (when it starts the ignition) every normal car has 2 sensors and monitors all the time the second sensor to compensate with VE losses going up mountains / hills etc..
Tks
TangoMan
posted on 6/4/07 at 03:05 PM Reply With Quote
It should read atmospheric 100KPa (or depending on height) as there is no manifold vacuum.
Summer's here!!!!
piddy
posted on 6/4/07 at 03:10 PM Reply With Quote
I'm with you now.
The reason I asked is my car won't start today. When it normally starts the Kpa is about 30 on tick over.
When I turn on the ignition only today it reads 90 (I'm not sure what it normally reads)
This shouldn't be the problem then should it?
the_fbi
posted on 6/4/07 at 06:14 PM Reply With Quote
Unfortunately that sounds fine.
