Author: Subject: rover v8 mega squert
ceebmoj
posted on 17/5/07 at 11:58 AM Reply With Quote
Right I have been thinking about this for a bit but its finally time to go to switch to mega squirt on the Marcos. I have a 3.5 RV8 presently running on carbs and a distrebuter.
Eventually I would like to be running on motorcycle TB’s a but was going to stage the switch over first doing sparks then sorting out the TB’s
I was going to get a full MS kit + box and relay board what other mods \ additions do I need I would like to bild the MS from a kit.
Does any one have any links to a good web sight detailing the install on a Rv8?
Can I completely remove my distributor and plug the hole?
posted on 17/5/07 at 12:24 PM Reply With Quote
of course you can mate as long as you don't expect to have oil presure!
(the camshaft drives the dizzy via skew gears, slot in end of dizzy drives oil pump)
I know someone who fitted MS to v8 in a land rover.
[Edited on 17/5/07 by 02GF74]
Agriv8
posted on 17/5/07 at 12:44 PM Reply With Quote
fitted vems ( similar to MS but a few more options ) on RV8
I Dont have a website .
if you wish to do fuel and spark you will need a set of 'waisted spark coil packs'
Personally I would get it running fuel only and then UG to fuel and spark.
regards
Agriv8
ceebmoj
posted on 17/5/07 at 03:46 PM Reply With Quote
hi thanks for the info.
is there no way of removing distebutor and placing a gear at the bottem for the oil pump? As having the distrebutor conected but doing nothing seams a bit wastfule / untidy.
wy do you sugest geting the injection running befor the spark?
blake
TangoMan
posted on 17/5/07 at 06:21 PM Reply With Quote
Several people in the past have cut the tops off the dizzy and fitted a bearing to support the shaft.
I would suggest posting on here to get a view as one of the mods (and supplier of MS units) runs a V8 in his cobra.
I would go with fuel first and then add sparks, or go with both together. It seems a lot of effort just for sparks.
[Edited on 17/5/07 by TangoMan]
Summer's here!!!!
froggy
posted on 17/5/07 at 06:31 PM Reply With Quote
i got mine from the guy with the cobra and you can specify what you want from his site as i needed a few extra bits to control boost etc .it was just over £350 built and as i couldnt do it myself was worth the money ,but i would have a long browse on the ms forum as it can be heavy going or maybe im just a bit thick
Agriv8
posted on 17/5/07 at 09:31 PM Reply With Quote
still got my dizzie plugged in it has one advantage a quick way to tell if tdc on Compresion stroke or if you are 360 out.
Froggy stick at the ECU got mine running fuel and spark worth all the brain strain late nights - know its not proper spannerin !!!!
regards
agriv8
darrens
posted on 17/5/07 at 11:01 PM Reply With Quote
I have MS on 3.9 V8, bonza so far, utilising dizzy for tach signal at moment
Cheffy
posted on 22/5/07 at 07:56 AM Reply With Quote
Dan (Scutter) from this site has got a thread going about this at the moment on the V-8.org website.
Link
Hope that helps,
Martin.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
scutter
posted on 22/5/07 at 05:22 PM Reply With Quote
Bl**dy hell fella, you dug that one up. Good info on the site, but for cheapness i'm still planning to chop a dizzy down
ATB Dan.
