gy351100
posted on 18/5/07 at 10:33 AM |
fuel pipe
hi all
what fuel pipe diameter is suitable for a ford 2.0i dohc and what pressue shoul it be
cheers
[Edited on 18/5/07 by gy351100]
JAG
posted on 18/5/07 at 11:04 AM |
Pipe diameter - 8mm should suit either carbs or injection.....
...but pressure will be 1 or 2 psi for carbs or 45'ish psi with injection.
Really need to know which you've got
Justin
Bluemoon
posted on 18/5/07 at 01:07 PM |
i= injection?
Chippy
posted on 18/5/07 at 07:19 PM |
Agree that 8mm pipe will be fine for all instalations. Think that the pressure for carbs is a bit higher than 1 or 2 psi, my old 1600 Xflow used to
run with a pump producing 4.25 psi. My present engine, (V6), injection pump runs 5 bar stalled, and thats a bit more than 70 psi, although the
pressure regulator cuts that to around 3 bar, (42 psi). HTH Ray
Dave Bailey
posted on 22/5/07 at 10:07 PM |
Ive been told that 6mm ID will be o.k. for 200+ Bhp (injection @ about 3 bar)... In fact I bought some nylon hose from lolocost and the size is 6mm
ID. I do hope they are right. I should sit down and calculate the flow rate I suppose......and check but that probably will make my brain hurt!
Anyone got a concern with 6mm ID?
Dave B
