Micael
posted on 20/5/07 at 07:03 PM |
How do you guys synchronize your TB:s?
I'm trying to synchronize my Gixxer TB:s. I have read somewhere that i
could use a hose and listen to the "swosh" in the inlet.
I can hear the swoch but i cant get it to sound exactly same on all four.
Do you guys have any tips or trix?
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
theconrodkid
posted on 20/5/07 at 07:14 PM |
i use a carb balancer,cant see any on flea bay at the mo,spose they are a bit old skool now
who cares who wins
pass the pork pies
Werner Van Loock
posted on 20/5/07 at 07:21 PM |
you could always buy the following
ebay
http://www.clubstylus.be
posted on 20/5/07 at 07:31 PM |
Done my Kawasaki T/Bs using a single vacuum gauge , don't even have to take the air filter off to do it. A set would be easier/quicker but not
worth the expense
Doug68
posted on 20/5/07 at 07:37 PM |
What you really want is one of these they are much more accurate and cheaper too than the dial
gauges.
Fatgadget
posted on 20/5/07 at 07:49 PM |
Whats wrong with using a length of rubber hosing and your ear like we used to do it when setting up a pair of twin forties?
It's locost that for sure and does the job too.
TangoMan
posted on 20/5/07 at 08:49 PM |
I used an old bottle cap, similar to a gearbox oil lid but bigger, with a piece of tub attached.
This captured all air going into the TB and was then fairly easy to get then match. One of these days I will borrow a proper carb balancer to se how
close I got.
Summer's here!!!!
Micael
posted on 20/5/07 at 09:11 PM |
Tell me more Tangoman.
I have tested the rubber-hose-ear-thing and i really can't get it right.
Micael Moose Åman
2009
TangoMan
posted on 20/5/07 at 09:19 PM |
Micael,
It is just a case of finding something to block off all other air entry into the TB except for that which is sucked through your tube.
Once you have captured all the intake air, it is easier to match the sound of them all.
Summer's here!!!!
posted on 20/5/07 at 09:43 PM |
I'd add a vote for carbtune......
Cheap considering that properly sync'd carbs can save petrol (therefore money) and provide extra ponies.......
stevebubs
posted on 21/5/07 at 08:07 AM |
I just used an old fashioned synchrometer...
martyn_16v
posted on 21/5/07 at 04:20 PM |
You could knock up a locost manometer from a board of wood, a few p-clips and a decent length of clear washer tubing. Fill it with coloured
water/antifreeze, make sure it's tall enough and has a long enough tube going to the tb that the liquid won't get sucked into the engine,
and robert's your mothers brother
Micael
posted on 21/5/07 at 05:39 PM |
I have a Pitot tube somewhere.
It might come in use for this. I'll let you know my findings.
Pitot tube info
http://www.flowmeterdirectory.com/flowmeter_artc/flowmeter_artc_02111201.html
Micael Moose Åman
2009
