supercat
| posted on 11/6/07 at 09:13 AM |
Crank Sensor Wiring
Hello,
I have a Zetec (I think) 2 pin inductive sensor for my crank pickup - does it matter which pin is earth?
James
Dusty
| posted on 11/6/07 at 10:02 AM |
yes.
supercat
| posted on 11/6/07 at 12:39 PM |
Splendid
peterrosey
| posted on 13/6/07 at 11:12 AM |
Had exactly the same issue when wiring in my Emerald to the crank sensor on my Zetec SE. Basically try it one way and see if the ECU 'sees
it' (on the Emerald the LED changes colour to indicate engine rotation). If it doesn't, just reverse the wires. On the Emerald you
can't damage the ECU by getting the wires reversed.
supercat
| posted on 13/6/07 at 11:33 AM |
Thats good to know, I'm using Emerald!
