se7ensport
posted on 24/6/07 at 08:31 PM |
fuel tank paint
I'll need to cut a hole to fit my in tank pump and sender, what should I use to paint over the cut steel edges that won't be affected by
the petrol?
Alex
RazMan
posted on 24/6/07 at 08:54 PM |
I don't think you really need to coat any cut edges that will be submersed in petrol - most steel tanks are not coated on the inside. The usual
primer and top coat should be sufficient for the exterior parts.
Raz
se7ensport
posted on 24/6/07 at 09:52 PM |
thanks for that, redoxide & hammerite it is then
