Furious D
posted on 29/6/07 at 09:18 AM |
Rocker Cover Gasket
Need a new one for the Tiger. I have tried phoning Ford, not much help.....
What car is it for......
What year is it........
It is a 2.0L Pinto, can anyone help, would like to get it today. Does anyone have the part number for Ford and then i will phone another parts
department.
D
Furious D
posted on 29/6/07 at 09:26 AM |
Are they all the same for a 2.0L Pinto then?
D
UncleFista
posted on 29/6/07 at 09:52 AM |
It'll be cheaper to source gaskets from your local motor factors.
I called at a dealers last week for an inlet and exhaust gasket for a Zetec, they wanted £40, I got a full top-end set on ebay for £35...
Tony Bond / UncleFista
bilbo
posted on 29/6/07 at 10:10 AM |
IIRC later pinto heads (certainly the Injection models, but may be others as well) had a wider rocker cover gasket. It may be that they're
interchangeable, but I'm not sure. Do you know where your head came from, it's age?
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
thesnake505
posted on 29/6/07 at 10:11 AM |
there are two types of rocker cover for the pinto engine, one has a wide sealing face one has a narrow face, have a look at which u have then go to
local motor factors it will be a couple of quid, if un sure about gasket needed, remove the old one and take it in to the shop, compare to the new one
:-) hope this helps
Furious D
posted on 29/6/07 at 10:15 AM |
:-) hope this helps
I think that this is going to be the best option. Will take it off tonight then get one tomorrow morning.
D
marshall
posted on 29/6/07 at 10:30 AM |
have you tryed burton motorsport they
do all ford spare parts....
DarrenW
posted on 29/6/07 at 11:06 AM |
gaskets for classics will be your freind. They have helped me out loads in the past. Great to deal with.
Furious D
posted on 29/6/07 at 11:20 AM |
Looks like a good website. Just spoken to local motor factors but thanks for that.
D
DarrenW
posted on 29/6/07 at 11:30 AM |
No probs F.
Local factors always get my cash first but GFC do some obscure stuff for old cars as well that are hard to get hold of. Last gasket set was only £35
or so and i was amazed how good the customer service was for such a low order. Their head bolts were a good price as well.
jollygreengiant
posted on 29/6/07 at 01:50 PM |
The mating face is the same on the heads. the only difference between any of the pinto's was with the rocker box flange. The later rocker boxes
also had special load spreading washers that went between the bolt and cover.
Genuine ford gaskets also had anti squash pins in the gasket either side of each bolt hole.
Later rocker covers when measured from outside of cover to edge of lip the distance is approx 20mm. Early cover the same distance is about 10mm.
Hope this helps.
[Edited on 29/6/07 by jollygreengiant]
