Author: Subject: Injection Fuel Filter
darrens
posted on 6/7/07 at 10:58 AM Reply With Quote
Off down to breakers, anyone one know a car which is easy one to get to. Needs to have decent flow, V8. Just found a crack down mine.
[Edited on 6/7/07 by darrens]
twybrow
posted on 6/7/07 at 11:22 AM Reply With Quote
Surely just order one new?! They cost about £6. why not look at old range rovers etc?
darrens
posted on 6/7/07 at 04:28 PM Reply With Quote
what's the difference then between the ones at 50 odd quid and ones around 6 - 10 quid.
As said this would be for FI not carb.
posted on 6/7/07 at 05:18 PM Reply With Quote
Go to your local motor factors and get a new one. Not worth the hassle finding and fitting a second hand one. Would you fit a second hand oil filter???
bigboytone
posted on 6/7/07 at 05:31 PM Reply With Quote
vauxhall astra ones are good...8mm flared conection on each end comes with small mounting bracket
zetec
posted on 6/7/07 at 09:20 PM Reply With Quote
Fit a pre and post pump filter. The post ones, as said Vx Senator/Carlton 8mm in/out are good, are cheap. The more £££ tend to be cleanable and come in a few different size in/out connections...and pretty colours!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
