liam.mccaffrey
posted on 12/7/07 at 03:52 PM |
Megasquirt v8 mod?
i have a MS1 v3 with 2 VB921's which i haven't used yet, due to a change in plans i would like to how easy is it to add another 2 so i can
run 2 lots of 4 lead coil packs for a v8 project
[Edited on 12/7/07 by liam.mccaffrey]
Build Blog
Build Photo Album
matt_claydon
posted on 12/7/07 at 04:11 PM |
Pretty easy; you need to find somewhere to mount the new VB921 (either in the proto area with individual heatsinks or on the case are common places)
then just run wires to the appropriate places (grounds where the other VB921s are grounded and triggers to LED18 and processor pin 15 IIRC) on the PCB
and the outputs to spare pins on the DB37 connector. Then just need to do the necessary changed to the 'codebase and outputs' section in
Megatune.
matt_claydon
posted on 12/7/07 at 07:11 PM |
Agree with CalvinX on that, makes life a lot easier too as the DB37 is not so jammed full of wires.
As an aside, personally I wouldn't use a DB15, I'd go for a more robust 'automotive' type connector (you only need 4 pins for
the coils) - I really think the DB type connectors are not best suited to the rigours of being in a car, but unfortunately replacing the DB37 with
something better is not an option due to the fact it is PCB mounted.
liam.mccaffrey
posted on 12/7/07 at 08:07 PM |
my apologies but i didn't assemble my MS and am not intimately familiar with its innards but
can i re-route(away from the DB37) the existing outputs from the 2 VB921's and take them, along with the 2 new VB921 outputs, out through a
dedicated connector?
of course all without destroying the unit?
Build Blog
Build Photo Album
Micael
posted on 13/7/07 at 07:42 AM |
has anyone done a mod to use an "ampseal" connector instead of the DB37?
I really don't like the looks of all wires in my DB37. At least not when there are both coil outputs and VR-cables cramped together.
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
liam.mccaffrey
posted on 13/7/07 at 09:02 AM |
any idea where to get an 8 way amp seal connector from?
would this type from maplin be ok its quite big though
http://www.maplin.co.uk/images/Full/n02cy.jpg
[Edited on 13/7/07 by liam.mccaffrey]
Build Blog
Build Photo Album
