iiyama
posted on 9/8/07 at 06:40 PM |
Relays.....
Im thinking :-
Headlights
Indicators
Fan
Fuel Pump
Starter motor
Horns
Anything else???
If its broke, fix it. If it aint broke, take it apart and find out how it works!
big_wasa
posted on 9/8/07 at 06:55 PM |
Starter has its own relay. it will draw about 10amps.
Again the flasher relay is a relay.
iiyama
posted on 9/8/07 at 07:18 PM |
Understand that, dont think my post was clear!
Each one of the above items will have its own relaly, are there any other items I havent listed that will require orbe better to have a relay?
caber
posted on 9/8/07 at 11:06 PM |
I did separate relays for main and dip beam though you could use a changeover relay for the two.
Caber![](/images//smilies/wink.gif)
iiyama
posted on 10/8/07 at 06:09 AM |
Thats what I intended to do, use a changeover. Seemed like a sensible thing to do!! ![](/images//smilies/smile.gif)
posted on 10/8/07 at 08:40 AM |
is that allowed? From all the cars I have driven and can remember, if you pull the main beam stalk (interemiitant switch)with the head lamps on, both
bulbs come one - I don't do it for long as I am sure the heat is not doing the bulbs any favours.
DaveFJ
posted on 15/8/07 at 03:09 PM |
the standard Tiger loom has 6 fuses 1 relay and a flasher unit.... I think that is an absolute minimum and if I was to make my own loom would
undoubtedly use more relays!.. as it is I have added 2 more relays and several more fuses for my Megasquirt fuel injection system, HP pump and LC1
wideband O2 etc...
I don't think many would reccomend the Tiger loom as an example of the best practice when making your loom nut it may provide some ideas - the
wiring diagram is on my website....
HTH
Dave
TimC
posted on 15/8/07 at 04:44 PM |
Looks sensible to me.
rusty
posted on 17/8/07 at 09:20 AM |
If your control switches are rated to take the load why add more cost and complicated wiring and use relays.
Heavy load items like the fan which have to be switched from a small temp switch I aggree need a relay but if your switches for the lights can handle
the load then why use a relay.
